getCapabilities not valid XML (MSXML)
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Nov 13 08:54:02 EST 2007
Steven,
The EMPTY element declaration in the DOCTYPE was simply inspired from
the example found in the spec itself (in Annex A.2 of WMS 1.1.1 and also
present in most/all previous revisions).
I'm no XML guru so I'm not sure what the best fix is, but once you find
out I'd invite you to file a ticket documenting the original problem and
the new format that makes MSXML and other parsers happy.
Daniel
Steven M. Ottens wrote:
> Hi all,
> My mapbuilder/openlayers application wasn't working on IE7, it
> complained that the WMS getCapabilities doc generated by Mapserver
> wasn't valid XML. I've finally tracked it down to the doctype declaration:
> Mapserver produces
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE WMT_MS_Capabilities SYSTEM
> "http://schemas.opengeospatial.net/wms/1.1.1/capabilities_1_1_1.dtd"
> <!ELEMENT VendorSpecificCapabilities EMPTY>
> ]> <!-- end of DOCTYPE declaration -->
> The parser removes both the <?xml ..> tag and the <!DOCTYPE ..> tag from
> the XML before parsing. So normally the to-be-parsed XML text starts with:
> Which is a valid piece of XML
> However MSXML apparently thinks that the closing > after EMPTY belongs
> to the opening < before !DOCTYPE. So instead now the XML text starts with:
> Which obviously isn't valid XML and MSXML fails.
> So my questions:
> -Anyone else noticed this problem?
> -Why is there an (empty!) ELEMENT declaration within the DOCTYPE?
> -How can I remove this ELEMENT?
> Regards,
> Steven
Daniel Morissette
http://www.mapgears.com/
