Upgrading Mapscript from 4.10.1 to 5.0 causes an Apache crash
Julien
g2c.martel at ORANGE.FR
Wed Nov 14 05:39:58 EST 2007
Sorry for the wrong reply adress.
The crash happens with every request. In fact it is just impossible to
display the map. I am using GD 2.0.35, built from source, no other
version existing on the system...
Umberto Nicoletti a écrit :
> Please keep the list in cc or to.
> Does the crash happen with every request or only once in a while, say
> after 10 minutes?
> Which gd are you using and/or have you got another gd lying around in
> your system path?
> Umberto
> On Nov 14, 2007 9:17 AM, Julien <g2c.martel at orange.fr> wrote:
>> shp2img works perfectly. here are my configure options :
>> ./configure --with-proj --with-wmsclient --with-ogr --with-libwww
>> --with-gdal --enable-runpath --enable-debug --without-tiff
>> --with-gd=/usr/local --with-freetype=/usr/local --with-threads
>> --with-curl-config=/usr/bin/curl-config --with-wfs --with-wcs
>> --with-wmsclient -with-wfsclient --with-php=/usr/src/php-4.4.4/
>> --with-httpd=/www/bin/httpd --with-geos=/usr/local/bin/geos-config
>> --with-mapscript
>> Above path are correct and libraries are detected the right way...
>> Could you document *precisely* how you built php mapscript (configure
>> flags, etc)?
>> Also try to run the shp2img utility on one of the crashing map files
>> to see if you can reproduce the error.
>> Umberto
>> On Nov 13, 2007 2:40 PM, Julien <g2c.martel at orange.fr> wrote:
>> Hi all (sorry if double posted),
>> Upgrading Mapserver/Mapscript from 4.10.1 to 5.0 causes an apache crash on
>> our server, with all our projects (with more or less complex mapfiles). I
>> have no error during mapscript compilation. When PHP is installed as an
>> apache DSO the error log reports the following errors :
>> *** glibc detected *** /www/bin/httpd: free(): invalid next size (fast):
>> 0x0867db38 ***
>> [Wed Nov 7 13:54:06 2007] [notice] child pid 23219 exit signal Segmentation
>> fault (11)
>> When PHP is installed as a CGI executable, the error log reports the
>> following :
>> [Thu Nov 8 14:56:46 2007] [error] [client xxx.xxx.xxx.52] Premature end of
>> script headers: /www/cgi-bin/php
>> Downgrading to 4.10.1 makes everything working back again. I didn't
>> succeeded in replicating the problem on a test machine using
>> the same software environnement.
>> Here's my software environnement (everything built from source) :
>> Ubuntu 6.10 Server
>> Apache 1.3.39 with OpenSSL 0.9
>> PHP 4.4.4 (I tried to build php as an Apache DSO as well as CGI, both are
>> crashing)
>> Curl and LibCurl 7.15.5
>> Freetype 2.3.4
>> GD 2.0.35
>> Gdal 1.4.3
>> GEOS 2.2.3
>> GeoTiff 1.2.3
>> Tiff 3.7.1
>> Zlib 1.2.3
>> Any help would be greatly appreciated.
>> Julien MARTEL
>> Technicien Informatique et Réseaux
>> 2 Avenue Madeleine Bonnaud
>> Parc d'Activités, Point Rencontre
>> 13770 Venelles - FRANCE
>> Tel : +33 (0) 4 42 54 00 68 Fax : +33 (0) 4 42 54 06 78
>> e-mail : j.martel at g2c.fr web : www.g2c.fr
>> Lire les conditions légales d'utilisation de cet e-mail
>> Venez nous retrouver sur les prochains salons
>> Orange vous informe que cet e-mail a ete controle par l'anti-virus mail.
>> Aucun virus connu a ce jour par nos services n'a ete detecte.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/17787d09/attachment.html
