Upgrading Mapscript from 4.10.1 to 5.0 causes an Apache crash
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Nov 14 08:28:58 EST 2007
sorry, a typo, I meant gdb (gnu debugger)
Umberto
On Nov 14, 2007 1:29 PM, Julien <g2c.martel at orange.fr> wrote:
> # gd php
> -bash: gd: command not found
> Unfortunately, I have no "gd" binary on my system.
> gd2copypal
> gdcmpgif
> gd2togif
> dlib-config
> gd2topng
> gdparttopng
> gdtopng
> Are the only binaries related to GD I can use... Where did you find that
> "gd" executable ? Is is a compilation flag ?
> Umberto Nicoletti a écrit :
> If you can run php on the cli and try to debug it with gd.
> Example:
> suppose the crashing page is mapserver.php
> just run:
> shell > gd php
> gd > start mapserver.php
> and post the otuput.
> Umberto
> On Nov 14, 2007 11:39 AM, Julien <g2c.martel at orange.fr> wrote:
> Sorry for the wrong reply adress.
> The crash happens with every request. In fact it is just impossible to
> display the map. I am using GD 2.0.35, built from source, no other version
> existing on the system...
> Please keep the list in cc or to.
> Does the crash happen with every request or only once in a while, say
> after 10 minutes?
> Which gd are you using and/or have you got another gd lying around in
> your system path?
> Umberto
> On Nov 14, 2007 9:17 AM, Julien <g2c.martel at orange.fr> wrote:
> shp2img works perfectly. here are my configure options :
> ./configure --with-proj --with-wmsclient --with-ogr --with-libwww
> --with-gdal --enable-runpath --enable-debug --without-tiff
> --with-gd=/usr/local --with-freetype=/usr/local --with-threads
> --with-curl-config=/usr/bin/curl-config --with-wfs --with-wcs
> --with-wmsclient -with-wfsclient --with-php=/usr/src/php-4.4.4/
> --with-httpd=/www/bin/httpd --with-geos=/usr/local/bin/geos-config
> --with-mapscript
> Above path are correct and libraries are detected the right way...
> Could you document *precisely* how you built php mapscript (configure
> flags, etc)?
> Also try to run the shp2img utility on one of the crashing map files
> to see if you can reproduce the error.
> Umberto
> On Nov 13, 2007 2:40 PM, Julien <g2c.martel at orange.fr> wrote:
> Hi all (sorry if double posted),
> Upgrading Mapserver/Mapscript from 4.10.1 to 5.0 causes an apache crash on
> our server, with all our projects (with more or less complex mapfiles). I
> have no error during mapscript compilation. When PHP is installed as an
> apache DSO the error log reports the following errors :
> *** glibc detected *** /www/bin/httpd: free(): invalid next size (fast):
> 0x0867db38 ***
> [Wed Nov 7 13:54:06 2007] [notice] child pid 23219 exit signal Segmentation
> fault (11)
> When PHP is installed as a CGI executable, the error log reports the
> following :
> [Thu Nov 8 14:56:46 2007] [error] [client xxx.xxx.xxx.52] Premature end of
> script headers: /www/cgi-bin/php
> Downgrading to 4.10.1 makes everything working back again. I didn't
> succeeded in replicating the problem on a test machine using
> the same software environnement.
> Here's my software environnement (everything built from source) :
> Ubuntu 6.10 Server
> Apache 1.3.39 with OpenSSL 0.9
> PHP 4.4.4 (I tried to build php as an Apache DSO as well as CGI, both are
> crashing)
> Curl and LibCurl 7.15.5
> Freetype 2.3.4
> GD 2.0.35
> Gdal 1.4.3
> GEOS 2.2.3
> GeoTiff 1.2.3
> Tiff 3.7.1
> Zlib 1.2.3
> Any help would be greatly appreciated.
> Julien MARTEL
> Technicien Informatique et Réseaux
> 2 Avenue Madeleine Bonnaud
> Parc d'Activités, Point Rencontre
> 13770 Venelles - FRANCE
> Tel : +33 (0) 4 42 54 00 68 Fax : +33 (0) 4 42 54 06 78
> e-mail : j.martel at g2c.fr web : www.g2c.fr
> Lire les conditions légales d'utilisation de cet e-mail
> Venez nous retrouver sur les prochains salons
> Orange vous informe que cet e-mail a ete controle par l'anti-virus mail.
> Aucun virus connu a ce jour par nos services n'a ete detecte.
