Migrating from Windows to Linux: trouble with mapfiles
Steven De Vriendt
gisaalter at GMAIL.COM
Wed Nov 14 11:08:09 EST 2007
Gregor,
I'm trying to access my wms in qgis. When I access this url in qgis:
http://80.201.239.208:8888/cgi-bin/mapserv?map=/etc/mapserver/wmsserver.map&version=1.1.0&service=wms&request=getcapabilities
I'm getting an error that qgis can't access the postgis db.
However, when I try to connect to postgis-db in qgis using same connection
params I can access it just fine...strange..
Steven
On Nov 14, 2007 5:02 PM, Gregor Mosheh <gregor at hostgis.com> wrote:
> Steven De Vriendt wrote:
> > Gregor:
> > this is my layer-setup for postgis-wms..
> > am I missing out something ?
> When you request the layer, what is your request? I ask because you have
> a wms_title, so I wonder whether you're requesting layer grens or layer
> gemeentgrens -- it should be grens.
> Other than that, looks great. What is it doing instead of working? When
> you hit mapserv directly via a manual WMS request, does it generate a
> blank image, or an error? Do you have a WMS URL pointing at this layer,
> which we could use to check?
> I might also recommend that you go over the WMS Server HOWTO on the
> website, just in case something got overlooked. Check the usual stuff:
> projections, wms_srs listing, read your WMS server's capabilities
> document and make sure it's sane, ...
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071114/d2d3139e/attachment.html
