Problems with Java Mapscript
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Nov 19 06:06:19 EST 2007
Try to change the imagetype to png:
IMAGETYPE png
and please send txt/plain only emails to this list.
Umberto
On Nov 19, 2007 11:50 AM, Luis Conti <conti_lui at gva.es> wrote:
> Sorry, my last message don't see correctly.
> Hello:
> I'm new using Java Mapscript but I can't execute the examples (
> DrawMap.java) with my testmap.map.
> This is my system.
> Linux OpenSuse 10.2
> mapserv -v results
> MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> Java -v results
> java version "1.5.0_08"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_08-b03)
> Java HotSpot(TM) Client VM (build 1.5.0_08-b03, mixed mode, sharing)
> the Java IDE is netbeans 5.5.1
> This is my testmap file:
> MAP
> NAME servidor
> EXTENT 626680 4191039 817176 4519393
> SYMBOLSET "etc/symbol.sym"
> FONTSET "etc/fonts.txt"
> IMAGECOLOR 255 153 255
> IMAGETYPE jpeg
> RESOLUTION 96
> WEB
> IMAGEPATH "/var/www/tmp"
> IMAGEURL "/tmp"
> METADATA
> "wms_title" "servidor wms icv"
> "wms_online_resource"
> "wms_srs" "EPSG:23030 EPSG:25830 EPSG:4230 EPSG:4258"
> END
> END
> REFERENCE
> EXTENT 626690 4186545 823410 4519390
> IMAGE "./key_map.png"
> SIZE 150 200
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> PROJECTION
> "init=epsg:23030"
> END
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> FORMATOPTION "QUALITY=100"
> END
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT ON
> FORMATOPTION "INTERLACE=ON"
> END
> OUTPUTFORMAT
> NAME gif
> DRIVER "GD/gif"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> EXTENSION "gif"
> TRANSPARENT ON
> END
> LAYER
> NAME "rios_principales_1000"
> GROUP "Hidrografía"
> CONNECTION "host=****** port=****** dbname=capas user=*******
> password=******"
> CONNECTIONTYPE Postgis
> DATA "the_geom from rios_principales_1000"
> TYPE LINE
> METADATA
> "wms_name" "rios_principales_1000"
> "wms_group_title" "Hidrografía"
> END
> CLASS
> NAME "riosPpal1000"
> TITLE ""
> SIZE 4
> COLOR 0 112 255
> LABEL
> ANGLE AUTO
> MINDISTANCE 1500
> COLOR 190 232 255
> OUTLINECOLOR 0 112 255
> SIZE 8
> TYPE truetype
> FONT "fritqat-italic"
> POSITION auto
> END
> END
> STATUS ON
> END
> END
> The same testmap.map works fine with php_mapscript.
> When execute the DrawMap.java example crash in the line (43)
> imageObj img = map.draw();
> This is the error:
> Exception in thread "main" java.lang.UnknownError: Unable to initialize
> image.
> at edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw (Native Method)
> at edu.umn.gis.mapscript.mapObj.draw(mapObj.java:382)
> at es.gva.icv.jmapscript.DrawMap.main(DrawMap.java:43)
> I have searched about this error in internet, but I have found nothing.
> Thanks in advance.
> Luis Conti
