raster with large grid cell size shifting
Simon Haddon
simon at SIBERN.COM.AU
Wed Nov 21 16:05:53 EST 2007
Hi Frank,
Thank you very much. I have been ripping my hair out over that one.
Cheers,
Simon
Frank Warmerdam wrote:
> Simon Haddon wrote:
>> Hi,
>> I wasn't quiet sure what subject heading to give this problem. I
>> hope it
>> is ok.
>> I have a map file which creates maps in decimal degrees. The data is a
>> mix raster and vector. It is the raster data which I am having trouble
>> with.
>> If I have any raster data with a large grid cell size (ie: 25 km) the
>> generated map always has complete pixels (cells) created. There are
>> never
>> any truncated pixels. As a result pixels don't even maintain their
>> correct relative position and can be seen differently, compared to the
>> overlayed point and polygon data, depending on how fair you move or
>> resize
>> the map.
>> If I move the map a whole pixel cell size the pixels redraw in their
>> correct position. If a move the map 1/2 a pixel cell size then the
>> pixels
>> move to fit the image. This can also extend to stretching the pixel
>> cells
>> to always ensure that a complete set of cells are displayed on the map
>> Has anyone had any experience with this problem and does anyone have any
>> suggestions about how to fix it.
> Simon,
> This is due to an optimization in MapServer to use the GDAL RasterIO()
> call
> for up/down sampling. The net result is that requests are always made
> on "pixel boundaries" and you get the result you see. If you add the
> line:
> PROCESSING "RESAMPLE=NEAREST"
> then MapServer will use a more general resampling code chunk which
> will give
> better results, but at some performance cost.
> Best regards,
