UPDATE Re: C# Mapscript ASP.NET Deployment Problem
Bruno Gendron
bruno_gendron at YAHOO.COM
Fri Nov 30 08:35:45 EST 2007
Hi Tamas,
First, sorry for not answering your message sooner, I've been very busy
since last Sunday trying to understand what's going on.
To make a short story, our ASP.NET 2.0 webapp is now deployed on a shared
server. We are using MS4W-2.2.6, with all dependencies. Right now, the web
page that uses C#Mapscript does not load because of the following security
exception:
System.Security.SecurityException: That assembly does not allow partially
trusted callers.
I suspect the problem I was getting last week was related to the same error.
I was hoping to get around this problem by re-compiling Mapserver with fewer
dependencies.
So, I've downloaded Howard Butler's Build Kit (version 4.8), and I managed
to get it to compile OK, but no manifest is created with mapscript.dll
(manifests are only created with mapserv.exe and other EXEs).
I also tried the default build kit nmake.opts file with other versions of
Mapserver (4.10 and 5.0), but in these cases, there is an error when
building csharp: something like "a syntax error occurred in input #1". So,
I'm unable to verify if a manifest will be created with the mapscript DLL.
Any ideas?
Yours,
Bruno
On Sun, 25 Nov 2007 00:40:28 +0100, Tamas Szekeres <szekerest at GMAIL.COM> wrote:
>I should also ask you about the mapserver version, which dependencies
>are compiled in, and the actual use case of your application that
>produce the problem with special regards of the usage of the mapscript
>objects.
>Best regards,
>Tamas
