MS 5.0 crashes on pdf output, 4.10.2 is OK
Maciej Sieczka tutey at O2.PL
Mon Oct 1 16:48:09 EDT 2007
MS 5.0 crashes on a map file with output type set as:
IMAGETYPE pdf
OUTPUTFORMAT
  NAME pdf
  DRIVER pdf
END
Examples:
./shp2pdf -m pdf.map -o pdf_ms5.pdf
*** glibc detected *** free(): invalid next size (fast):
0x08254f00 ***
./shp2img -m pdf.map -o pdf_ms5.pdf
0x08179608 ***
The same map file works OK with shp2img and shp2pdf from MS
4.10.2.
Both MS 4.10.2 and 5.0 built and running against the same
libraries, on the same machine. Both source codes were
configured with exactly the same switches.
Ubuntu Dapper 32bit, using PDFLib-Lite 7.0.2. If more
details are needed please let me know.
Maciek
