TIFF/TFW fails in v5.0
Bart van den Eijnden bartvde at GMAIL.COM
Tue Oct 2 02:56:45 EDT 2007
Just to confirm we've had this same problem with that particular FWTools
release on Fedora 3 using Geotiff files. Downgrading FWTools solved it for
us.
Best regards,
Bart
On 10/2/07, Jørn Vegard Røsnes <jorn at spacetec.no> wrote:
> Hi all,
> I have just migrated from Mapserver-4.9/FWTools to
> Mapserver-5.0/FWTools-1.3.7.
> In my map file I have some TIFF files with .TFW (world file).
> The problem is that mapserv returns:
> "msDrawMap(): Image handling error. Failed to draw layer named
> &#39;TROMS_LARGE&#39;.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format drawEPP(): Image handling
> error. /srv/www/htdocs/konserv/konservs1a/data/TROMS_LARGE.tif is not an
> EPPL
> file."
> The same map file works for mapserv 4.9.
> Here is my map file layer entry
> LAYER
> #stamp: 1189671749
>      NAME "TROMS_LARGE"
>      DATA "TROMS_LARGE.tif"
>      TYPE RASTER
>      STATUS ON
>      TRANSPARENCY 50
>      OFFSITE 0 0 0
>      DEBUG ON
>      CLASS
>           NAME ""
>           KEYIMAGE "/srv/www/htdocs/legends/terra_chlora_legend.png"
>      END
>      PROJECTION
>         "proj=stere"
>         "lat_0=63.0"
>         "lon_0=16.0"
>      END
> END
> I have also tried to rename the file to .tiff.
> Do you have some ideas?
> cheers
> Jørn Vegard
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071002/6e477739/attachment.html
