pdf output issues: labels garbled and not buffered,
lines "broken"
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Oct 4 02:58:23 EDT 2007
Maciej,
you should open a ticket for this issue and attach the sample data.
Regards,
Umberto
On 10/3/07, Maciej Sieczka <tutey at o2.pl> wrote:
> Hi,
> After apllying Umberto's patch for PDF output [1] I'm able
> to create pdfs with MapServer 5.
> However, I have the same issues I had with MS 4.10.2. In PDF
> the national characters in labels are garbled, labels are
> not buffered and vector lines have some turns not round in
> PDF while all these look nice and round in PNG.
> If anybody would like too look into this issue, please
> compare the attached PDF and PNG, both created with MS 5
> shp2img. The PNG is OK, PDF has artifacts. Is it my error or
> something else? The input shapefile and map file are here
> [2] (300 KB) if needed.
> Ubuntu Dapper 32bit, using PDFLib-Lite 7.0.2. If more
> details are needed please let me know.
> Cheers,
> Maciek
> [1]http://trac.osgeo.org/mapserver/attachment/ticket/2338/2338.patch
> [2]http://kufaya.googlepages.com/MS_sampledata.zip
