getFeatureInfo problem
Jan Jansen jansen at NIEUWLAND.NL
Fri Oct 5 05:23:37 EDT 2007
Hello list,
I have a problem with the WMS getFeatureInfo command. I have an Oracle Spatial POINT Layer.
GetFeatureInfo works fine, but when I zoom in to a certain scale, the request doesn't return any results.
request:
http://his-kust.ontwikkel.gisinternet.nl/cgi-bin/mapserv?map=/home/geodata/project_data/his/mapfiles/his_server_mapbuilder.map&reeks_id=2&stormfilter=1&&VERSION=1.1.0&REQUEST=GetFeatureInfo&LAYERS=kustduinsig&SRS=EPSG:28992&BBOX=87127.77696385694,469462.49761573685,87895.82254419167,469994.2214790455&WIDTH=650&HEIGHT=450&INFO_FORMAT=text/html&FEATURE_COUNT=1&QUERY_LAYERS=kustduinsig&X=322&Y=220
Tolerance in mapfile is set to a high level (20).
The X Y pixel location is exactly on the point (cross checked it with the getMap request)
Any idea's?
Thanks in advance,
Kind regards, Jan Jansen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071005/3ff31c9c/attachment.html
