map_get_template causes error
Jim O'Leary
joleary.public at GMAIL.COM
Mon Oct 8 10:53:29 EDT 2007
The same is true for map_web_header and map_web_footer. They cause this error
when sent as GET parameters to mapserver.exe. Removing them and hard coding
them in the map file specified in GET removes the error.
Jim O'Leary wrote:
> I have installed MS4W 2.2.6. The map_get_template parameter causes this
> error when a GET form is submitted to mapserver.exe:
> loadWeb(): Unknown identifier. Parsing error near (example2-1.html):(line
> 1)
> If I do not send that parameter and instead hard code TEMPLATE to
> example2-1.html in the map file specified in the GET, there is no error.
> Thanks.
View this message in context: http://www.nabble.com/map_get_template-causes-error-tf4588261.html#a13098263
Sent from the Mapserver - User mailing list archive at Nabble.com.
