FW: [UMN_MAPSERVER-USERS] Mapfile
Hayden Fisher
support at BIZEASSET.COM.AU
Tue Oct 9 00:36:59 EDT 2007
Hi Ian,
yes that sounds about right, the version I need will have to look at
directory structures and TAB files, those that are present will then be
included in creating a virtual mapfile for display.
So you built this in MapScript or your webpage?
Regards,
Hayden
Sent: Tuesday, 9 October 2007 4:51 AM
To: Hayden Fisher
Subject: RE: [UMN_MAPSERVER-USERS] Mapfile
Hayden,
I have been working on a site that generates the MAP file from a
database and then reads it. It does this every time someone accesses
the site. Is this what you are trying to do? Using MapScript you can
programmatically build the MAP file and not read it off the hard drive.
Cheers Ian
Ian Tidy
GIS Analyst / Developer
Works Asset Department
Napier City Council
mailto:iant at napier.govt.nz
http://www.napier.govt.nz <http://www.napier.govt.nz/> |
http://maps.napier.govt.nz <http://maps.napier.govt.nz/>
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hayden Fisher
Sent: Monday, 8 October 2007 7:54 p.m.
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapfile
Hi All,
I have got the TutorialMapServer running. Now I curious whether or not
you can, or if anyone else has dynamically created the mapfile? If it
can be created like XML Document Object programmatically and not be
literally saved to the hard drive? Then load when necessary.
Regards,
Hayden Fisher
Development and Support
BizeAsset Pty Ltd
support at bizeasset.com.au
Mob: (04) 3838 4747
Ph: (07) 3369 2222
Fax: (07) 3369 8883
Toll Free: 1800 836 850
This e-mail message has been scanned for Viruses and Content and cleared
by MailMarshal
Scanned by Bizo EmailFilter
<http://www.bizoservices.com/services/email_filter.html>
by MailMarshal
Attention:
This e-mail message and accompanying data may contain information that
is confidential and subject to legal privilege. Any information
provided is given in good faith. However unless specifically stated to
the contrary, Napier City Council accepts no liability for the
content of this e-mail or for the consequences of any action taken on
the basis of the information provided, unless that information is
subsequently confirmed in writing. If you are not the intended
recipient,
you are notified that any use, dissemination, distribution or copying
of this message or data is prohibited. If you received this e-mail
message in error, please notify us immediately and erase all copies
of this message and attachments. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071009/d35993cb/attachment.html
