Can I export MapInfo "styleitem" info to PostGIS?
Flavio Hendry flavio at TYDAC.CH
Wed Oct 10 05:48:13 EDT 2007
Hi Jacob
I do not think that you could do that as the moment. FME (www.safe.com)
would bring the styles along to PostGIS. However there is no way to
define any other STYLEITEM as "auto" at the moment. "auto" is more or
less limited to colors as far as I know. Ideal would be something like
COLORITEM pointing to a column containing RGB color info ...
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC Web-Site:  http://www.tydac.ch
TYDAC MapServer: http://www.mapserver.ch
############      Mit freundlichen Gruessen / Kind Regards
############             mailto:flavio at tydac.ch
############         TYDAC AG - http://www.tydac.ch
####    ####        Geographic Information Solutions
####    ####         Luternauweg 12 -- CH-3006 Bern
############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
From: "Delfos, Jacob" <Jacob.Delfos at MAUNSELL.COM>
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Wed, 10 Oct 2007 15:54:32 +0800
Subject: [UMN_MAPSERVER-USERS] Can I export MapInfo "styleitem" info to
PostGIS?
> Hi List,
> I'm in a situation where I have a huge amount of layers, and manually
> symbolising is not practical. All data is in MapInfo, which has the
> advantage that I can use "styleitem auto".
> However, due to a number of reasons I'll probably have to convert the
> setup to PostGIS. The question:
> Is it possible to carry the MapInfo style information across as an
> attribute, and point the styleitem to this attribute?
> Ogrinfo does not reveal any style-information, so ogr2ogr can not
> bring it across. Is there a solution to this? It would be absolutely
> ideal to be able to store symbology in PostGIS.
> Regards,
> Jacob
> JACOB DELFOS
> GIS ANALYST
> Maunsell Australia Pty Ltd
> 629 Newcastle Street, Leederville, WA 6007
> PO Box 81, Leederville, WA 6902
> Western Australia
> ABN 20 093 846 925
> Tel     + 61 8 9281 6185
> Fax    + 61 8 9281 6297
> jacob.delfos at maunsell.com
> This email and any attachments are intended solely for the named
> recipient and are confidential. The copying or distribution of them
> or any information they contain by anyone other than the named
> recipient is prohibited. If you have received this document in error,
> please notify the sender and delete all copies from your computer
> system and destroy all hard copies. It is the recipient's
> responsibility to check this email and any attachments to this email
> for viruses before use.
