problem invoking WCS: "no template"???
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Oct 10 12:05:42 EDT 2007
> I am trying to make the Web Coverage Service (WCS) feature work.
> However, GetCapabilies and GetCoverage requests both respond with
> "mapserv(): Web application error. No template provided."
> No doubt I have made some basic configuration error, but I
> cannot find my problem. The Web Map Service (WMS)
> functionality using the same mapfile does work.
> Here are the parts of my mapfile that I believe are relevant to WCS:
> # Added for WCS support
> OUTPUTFORMAT
> NAME GEOTIFF
> DRIVER "GDAL/GTiff"
> MIMETYPE "image/tiff"
> IMAGEMODE "BYTE"
> EXTENSION "tif"
> END
> # TEST WCS feature
> LAYER
> NAME "airstiff"
> TYPE RASTER
> DUMP TRUE
> METADATA
> "wcs_title" "AIRS TIFF Coverage"
> "wcs_nativeformat" "tiff"
> END
> STATUS off
> PROJECTION
> "init=epsg:4326"
> END
> DATA "/sivo/data/soar/airs/2007/01/04/12/bt.tiff"
> END
> NOTE: The same floating-point GeoTIFF (bt.tiff) is correctly
> read and classified by the WMS component.
> Is there something missing in my mapfile? This document:
> http://mapserver.gis.umn.edu/docs/howto/wcs_server/#d45e65
> claims that four conditions must be satisfied, as I believe I
> have done:
> Data source is of raster type that is processed using
> GDAL (e.g GeoTIFF, Erdas Imagine, ...)
> LAYER NAME must be set
> LAYER TYPE is RASTER
> LAYER DUMP parameter set to TRUE
> Thanks for any help,
> Jeff DLB
Jeff,
What does your request URL look like? Did you include service=WCS in
the request?
..Tom
