Can I export MapInfo "styleitem" info to PostGIS?
Delfos, Jacob Jacob.Delfos at MAUNSELL.COM
Wed Oct 10 19:59:11 EDT 2007
Daniel,Flavio,
Thanks for your replies. At least I know I won't have to bother pursuing
that if it doesn't work.
I may look into carrying color across. I tried using FME to get style
across, but I probably did it wrong, because it came out empty.
I'll look into whether I can write a script to assign colors
automatically based on an attribute.
Thanks,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Daniel Morissette
> Sent: 10 October 2007 21:08
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Can I export MapInfo
> Flavio Hendry wrote:
> > Hi Jacob
> > I do not think that you could do that as the moment. FME
> (www.safe.com)
> > would bring the styles along to PostGIS. However there is no way to
> > define any other STYLEITEM as "auto" at the moment.
> That's correct. The original plan was to eventually support binding
> STYLEITEM to any attribute which would contain a style string in the
> format that OGR produces/understands, but we never got to
> that and only
> STYLEITEM AUTO has been implemented.
> > "auto" is more or
> > less limited to colors as far as I know.
> AUTO also supports mapping symbols, fonts and about anything
> you find in
> MapInfo symbology. You need to have the right entries in your fontset
> and symbolset for the mapping to work. This should be covered
> by the OGR
> HowTo.
> > Ideal would be something like
> > COLORITEM pointing to a column containing RGB color info ...
> This is possible with v5.0, you'd use:
>     COLOR [mycolor]
> Where "mycolor" is the attribute name from the data source.
> Color can be
> given as a hex value (e.g. #FFFFFF) or an RGB triplet (e.g.
> 255 255 255).
> The following properties can accept bindings in 5.0:
> * Style: angle, color, outlinecolor, size, symbol
> * Label: angle, color, outlinecolor, size, font, priority
> That is the reason why LABELITEM, ANGLEITEM, etc were dropped in 5.0.
> e.g. LABELITEM was replaced by "LABEL [mylabelitem]", etc.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
This email and any attachments are intended solely for the named recipient and are confidential. The copying or distribution of them or any information they contain by anyone other than the named recipient is prohibited. If you have received this document in error, please notify the sender and delete all copies from your computer system and destroy all hard copies. It is the recipient's responsibility to check this email and any attachments to this email for viruses before use.
