Rename: Getting DBF data for symbology
Mevima Winn paulanne.winn at WACORP.NET
Fri Oct 12 13:23:28 EDT 2007
There are a couple of ways.
First is to set a transparency level, if the polygons have to be solid.
Underlying polygon doesn't have to have any, while the top polygon can have
any transparency level you want - probably somewhere between 40 and 60% if
you want both to be approximately equally visible.
Or you can simply set an OUTLINECOLOR and no COLOR, which means you will get
an outline and no fill, which will show any underlying polygons as long as
they don't directly overlap the same lines.  Any overlapping lines can be
identified by making the outline line thicker and a different color, so
whoever is viewing the map can see that there are multiple polygons there.
Regards,
-Mevima
  -----Original Message-----
  From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Hayden Fisher
  Sent: Thursday, October 11, 2007 10:47 PM
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Subject: [UMN_MAPSERVER-USERS] Rename: Getting DBF data for symbology
  Also polygons on top of polygons, is there a way to make it so you can see
both?
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.14.8 - Release Date: 10/11/2007 12:00
AM
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071012/4d52a292/attachment.html
