PHP/Mapscript and Zend Optimizer
Toomas Aas
toomas.aas at RAAD.TARTU.EE
Sun Oct 14 17:46:07 EDT 2007
Arkadi Shishlov wrote:
> If you need speed, Optimizer won't get you any.
> It is only for running Zend encoded PHP pages - means vendor lock-in.
Yeah, thanks, I knew that. Or at least, sort of suspected. I'm not
exactly sure *why* our developers want ZO. Maybe they need to run some
Zend encoded files.
> Use XCache http://xcache.lighttpd.net/ which is PHP5 compatible or just
> don't bother.
Thanks for the pointer, I wasn't aware of xcache. I've been using APC
(http://pecl.php.net/APC) until now. But it is said to be incompatible
with Zend Optimizer.
BTW, my Zend Optimizer problem got solved when I ripped out the lines
from php.ini that were put there by ZO install and replaced them with
just the following:
[Zend]
zend_optimizer.optimization_level=15
zend_optimizer.version=3.0.0
zend_extension=/usr/local/Zend/lib/Optimizer-3.0.0/php-5.1.x
/ZendOptimizer.so
Toomas
... I think, therefore I am overqualified.
