Rename: Getting DBF data for symbology
Todd Harris
Todd.Harris at LANDGATE.WA.GOV.AU
Mon Oct 15 21:21:26 EDT 2007
I have recently had the same problem with overlapping polygons at the
CLASS level, I solved it by using a hatch symbol that had a minimum
spacing value, thus allowing linework to appear through the hatching. It
will have a slight affect on the colour of the polygon on top but works
well.
STYLE
SYMBOL 'hatch135'
OUTLINECOLOR 0 0 0
COLOR 255 200 255 # light pink
END #STYLE
Todd
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fawcett, David
Sent: Monday, 15 October 2007 9:39 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Rename: Getting DBF data for
symbology
I believe that transparency/opacity currently is only available at the
layer level, not the class level as Hayden appears to want.
If you really need the transparency option, you could break out your
classes into separate layers. This would allow you to use transparency,
but would of course multiply the number of layers and may give you a
very small performance hit (which may likely be negligible).
David.
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Mevima Winn
Sent: Friday, October 12, 2007 12:23 PM
symbology
There are a couple of ways.
First is to set a transparency level, if the polygons have to be
solid. Underlying polygon doesn't have to have any, while the top
polygon can have any transparency level you want - probably somewhere
between 40 and 60% if you want both to be approximately equally visible.
Or you can simply set an OUTLINECOLOR and no COLOR, which means
you will get an outline and no fill, which will show any underlying
polygons as long as they don't directly overlap the same lines. Any
overlapping lines can be identified by making the outline line thicker
and a different color, so whoever is viewing the map can see that there
are multiple polygons there.
Regards,
-Mevima
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Hayden Fisher
Sent: Thursday, October 11, 2007 10:47 PM
Subject: [UMN_MAPSERVER-USERS] Rename: Getting DBF data
for symbology
Also polygons on top of polygons, is there a way to make
it so you can see both?
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071016/a3eeaf2f/attachment.html
