libmapscript.so: wrong ELF class: ELFCLASS64. Java Mapscript woes on AMD64
Rodrigo Del C. Andrade rodrigo.andrade at DIGITRO.COM.BR
Tue Oct 16 09:38:58 EDT 2007
    Hi Umberto, thanks for the reply.
    Silly me forgot to mention I had already tried with -d64 flag, only
to be greeted with a "Running a 64-bit JVM is not supported on this
platform.".
    But all is fine now: I guess a good night asleep jumpstarted the
neurons back,  'cause driving to work this morning it hit me: the JVM  I
am using is 32 bits.
    So I downloaded the 64bits JDK and lo and behold: it's alive again.
    Sometimes *obvious* smacks you in the face and you still cant see it.
    I'll get me coat and leave the building now.
    Thanks.
    Rodrigo
ps: I am forwarding this to the list for posterity's sake.
*Rodrigo Del C. Andrade*
/Programador/
/SIC - SSE - Soluções Segurança Pública/
*DÍGITRO TECNOLOGIA*
*E-mail:* rodrigo.andrade at digitro.com.br
<mailto:rodrigo.andrade at digitro.com.br>
*Fone:* +55 48 3281-7314 / +55 48 3281-7000
*Fax:* +55 48 3281-7299
*Site:* www.digitro.com <http://www.digitro.com>
Umberto Nicoletti wrote:
> Try to run one of the examples and add this command line option to java:
> -d64
> Example:
> java -d64 -classpath ./:examples/:./mapscript.jar
> -Djava.library.path=. DumpShp ../../tests/point.shp
>  google is your friend, found this searching for ELFCLASS64
> http://forum.java.sun.com/thread.jspa?threadID=5072865
> Umberto
> On 10/15/07, Rodrigo Del C. Andrade <rodrigo.andrade at digitro.com.br> wrote:
>>      Hello dear list.
>>      I was given a new machine to develop on and I am trying to get Java
>> mapscript to run on AMD64, Fedora Core 7 64bits, but I am getting a nasty
>> error when I try to 'make test' after compiling JavaMapscript (Mapserver
>> 4.1x series, from svn revision 6176. I havent had time to give 5.0 a go yet)
>>  [root at dinamico132 java]# make test
>>  javac -classpath ./:examples/:./mapscript.jar -d examples/
>> examples/ConnPool.java examples/DrawMap.java examples/DumpShp.java
>> examples/MakePoint.java examples/QueryByAttribute.java
>> examples/ShapeInfo.java examples/WxSTest.java examples/Metadata.java
>> examples/RunTimeBuiltWMSClient.java
>>  javac -encoding iso-8859-15 -classpath ./:examples/:./mapscript.jar -d
>> examples/ examples/QueryByAttributeUnicode.java
>>  java -classpath ./:examples/:./mapscript.jar -Djava.library.path=. DumpShp
>>  java.lang.UnsatisfiedLinkError:
>> /home/home2/install/mapserver_svn_6176/mapscript/java/libmapscript.so:
>>  make: *** [test] Error 255
>>      I am compiling mapsserver with
>>      ./configure \
>>     --prefix=$MAPSERVER_HOME \
>>     --without-pdf \
>>     --with-threads \
>>     --with-png=/home2/mapserver/libpng \
>>     --with-freetype=/home2/mapserver/freetype \
>>     --with-gd=/home2/mapserver/gd \
>>     --with-geos=/home2/mapserver/geos/bin/geos-config \
>>     --with-ogr=/home2/mapserver/gdal/bin/gdal-config \
>>     --with-gdal=/home2/mapserver/gdal/bin/gdal-config \
>>     --with-proj=/home2/mapserver/proj4 \
>>     --with-wfs \
>>     --with-wcs \
>>     --with-wmsclient \
>>     --with-wfsclient \
>>      after successfully building luibPNG, FreeType, GD, GEOS and GDAL to the
>> directories you can see on the configure line above, and I am using java
>> 1.6.0.
>>      I gotta admit I am new to this 64 bits business, but I looked around
>> and found references to compiling stuff with a -fPIC flag, so I went back
>> and recompiled everything manually adding a -fPIC to the compiler flags in
>> every Makefile along the way, but I still got the same error.
>>      Does anyone got a clue about this?
>>      Thanks!
>>  Programador
>>  DÍGITRO TECNOLOGIA
>>  E-mail: rodrigo.andrade at digitro.com.br
>>  Fone: +55 48 3281-7314 / +55 48 3281-7000
>>  Fax: +55 48 3281-7299
>>  Site: www.digitro.com
