Solaris AGG Compile...
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Tue Oct 16 09:28:45 EDT 2007
OK, so a standard 'make' would work, erroring on CC not being defined. I
made the following changes to Makefile.in.SunOS:
Changed:
CXX = CC
To:
CXX = gcc
Changed:
C = cc
To:
C = gcc
Changed:
LIB = CC -xar -o
To:
LIB = gcc -xar -o
Then I was able to begin running a 'make' but it dies with the
following:
gcc: language ar not recognized
Undefined first referenced
symbol in file
cos agg_arc.o
sin agg_arc.o
acos agg_arc.o
ceil agg_image_filters.o
fmod agg_bezier_arc.o
main
/usr/local/lib/gcc/i386-pc-solaris2.10/3.4.6/crt1.o
sqrt agg_bezier_arc.o
operator new[](unsigned int) agg_bspline.o
atan2 agg_curves.o
floor ctrl/agg_polygon_ctrl.o
vtable for __cxxabiv1::__si_class_type_infoctrl/agg_cbox_ctrl.o
operator delete[](void*) agg_bspline.o
operator delete(void*) ctrl/agg_cbox_ctrl.o
vtable for __cxxabiv1::__class_type_infoctrl/agg_cbox_ctrl.o
__gxx_personality_v0 agg_arc.o
__cxa_pure_virtual ctrl/agg_cbox_ctrl.o
ld: fatal: Symbol referencing errors. No output written to
libagg.a
collect2: ld returned 1 exit status
make[1]: *** [all] Error 1
make[1]: Leaving directory `/usr/local/agg-2.4/src'
make: *** [src/libagg.a] Error 2
Thanks.
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
Sent: Monday, October 15, 2007 3:32 PM
To: Nolte, Tim
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
More technical details would be helpful. I can offer my experience
although it may not be applicable. I have compiled on Solaris 9 using
the GNU make and ld. Be sure you are using GNU ld. The Sun version
didn't work for me.
-Trent
Nolte, Tim wrote:
> I'm at the end of my rope here. I'm running up against a deadline and
I
> can't get AGG compiled on Solaris 10 x86 for the life of me. I'm
afraid
> I'm going to end up having to go back to GD. I made the mistake of
using
> HostGIS to setup and interim mapserver while I rebuild the existing
one
> and decided to go with Solaris as the rest of our servers are running
on
> it. Anyways, if anyone has successfully compiled AGG on a Solaris box
it
> would help me out huge! Thanks.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
