[MI-L] Re: MapServer, IIS and ASP
Hayden Fisher support at BIZEASSET.COM.AU
Tue Oct 16 19:25:27 EDT 2007
Thanks David, found the problem "=" symbol should have been "eq"
Regards,
Hayden
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Tuesday, 16 October 2007 12:06 AM
To: Hayden Fisher; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] [MI-L] Re: MapServer, IIS and ASP
Hayden,
What do you mean by 'it is not working'?  It is a little tough to help
you with such general symptoms.
Another thing to try:  If your column Assettype is a string, I don't
think that your expression is correctly formed.  If it is a string, you
also need to quote the column name.
Try something like:  EXPRESSION ('[Assettype]'="Unknown")
David.
	-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hayden Fisher
	Sent: Thursday, October 11, 2007 11:12 PM
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: Re: [UMN_MAPSERVER-USERS] [MI-L] Re: MapServer, IIS and
ASP
	Hi All,
	Have MapServer MapScript running! I have MapInfo tables with DBF
data files. I am now trying to place different symbology for each asset
type. I have placed the layer portion of my MapFile below. This is what
I've tried so far, could someone take a look, as it is not working.
	Also polygons on top of polygons, is there a way to make it so
you can see both?
	       LAYER
	              NAME "wsregn"
	              STATUS default
	              TYPE polygon
	              MINSCALE 0.1
	              MAXSCALE 50000
	              CONNECTIONTYPE OGR
	              CONNECTION
"C:\Inetpub\wwwroot\biz_e_asset_new\AMS_Final\WS\REGIONS\CORE\wsregn.tab
	              PROJECTION
	                     auto
	              END
	              CLASSITEM "assettype"
	              CLASS
	                     EXPRESSION ([Assettype]="Unknown")
	                     STYLE
	                           COLOR 100 0 100
	                           OUTLINECOLOR 0 0 100
	                           SYMBOL 0
	                     END
	              END
	              CLASS
	                     EXPRESSION ([Assettype]="Building")
	                     STYLE
	                           COLOR 0 100 100
	                           SYMBOL 0
	                     END
	              END
	              CLASS
	                     EXPRESSION ([Assettype]="Land")
	                     STYLE
	                           COLOR 100 100 0
	                           SYMBOL 0
	                     END
	              END
	       END
	Regards,
	Hayden Fisher
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071017/b631c2aa/attachment.html
