Don't draw GIF/PNG images on wms clients.
Rahkonen Jukka Jukka.Rahkonen at MMMTIKE.FI
Wed Oct 17 06:22:00 EDT 2007
Your LAYER definition
    TYPE POLYGON
    CONNECTION "http://localhost/cgi-bin/mapserv.exe?map=comarca_wms.map"
    CONNECTIONTYPE WMS
means that you are trying to get data for your layer from WMS service from your localhost. In theory this might work (with TYPE RASTER because WMS is delivering images) but I believe you do not really have another, already working Mapserver WMS running on your computer.
What data are you going to serve with your WMS server? Local vectors or something from a remote WMS?
-Jukka Rahkonen-
	Lähettäjä: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Manuel Ballesteros Cardador
	Lähetetty: 17. lokakuuta 2007 12:55
	Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
	Aihe: [UMN_MAPSERVER-USERS] Don't draw GIF/PNG images on wms clients.
	Hi, I'm new in MapServer list.
	I have configured a WMS server and when I try viewing a .map file on wms clients (arcmap, qgis), images are not shown in. I can do zoom, pan, etc but it is not drawn.
	If I change resourceonline parameter I obtain drawEPP error.
	Do you have any idea?
	Thanks in advance!
	This is the .map file.
	MAP
	  NAME "COMARCA"
	  STATUS ON
	  EXTENT 286421 4210158 400752 4295906
	  SIZE 600 500
	  SHAPEPATH "./data"
	  IMAGECOLOR 125 125 125
	  UNITS METERS
	  IMAGETYPE PNG
	  WEB
	    IMAGEPATH "./tmp/ms_tmp/"
	    IMAGEURL "./tmp/"
	    METADATA
	      "wms_title" "WMS Adroches" ##required
	      "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
	      "wms_srs" "EPSG:23030"
	    END
	  END
	  PROJECTION
	    "init=epsg:23030" ##required
	  END
	  LAYER
	    NAME "Limite"
	    STATUS ON
	    DEBUG ON
	    DATA "comarca"
	    TYPE POLYGON
	    CONNECTIONTYPE WMS
	    METADATA
	      "wms_title"             "Limite Comarca"
	      "wms_name"              "Limite"
	      "wms_server_version"    "1.1.1"
	      "wms_format"            "image/PNG"
	    END
	    CLASS
	      NAME "Comarca"
	      STYLE
	        COLOR 170 253 172
	        OUTLINECOLOR 199 199 199
	      END
	    END
	  END # Layer
	END # Map File
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071017/534e80c9/attachment.html
