very large tile index
Ludovico Bianchini metlud at YAHOO.IT
Wed Oct 17 11:20:57 EDT 2007
if I understood completely those suggestions are for raster images. I'm in a
same trouble with a large (indexing 2500 tile) shape file index,
generated with tile4ms. How can I "mosaic" many shape files?
Ludovico
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, July 12, 2007 9:15 PM
Subject: Re: [UMN_MAPSERVER-USERS] very large tile index
> Chris -
> I will echo Frank's point from experience.  Your disk subsystem, while it
> may be good, is the slowest part of your system and you don't mention what
> it is.  Any disk is slowest at doing seeks from one location to another
> (as
> opposed to linear reads).  Your request is, at a minimum, asking your
> system
> to open and read 2,774 individual files.  Under optimal conditions this
> will
> probably require 2,774 seeks and possibly quite a few more (it wouldn't be
> surprising to have 5,000 - 10,000 seeks occur).
> A typical 7,200 RPM ATA drive will have a seek time of about 9
> milliseconds,
> and will have an average latency of about 4.2 milliseconds.  That means
> that
> a command to "open this file and read the header" will take a minimum of
> 13.2 milliseconds.  You can only do 70 of those in one second, so if you
> want to do it 2,774 times you will need 40 seconds just to open all those
> files.
> Your overviews can make things considerably worse.  If you wrote 2,774 TIF
> files to one directory, then ran gdaladdo 2,774 times on those files,
> you're
> going to append quite a bit of data to each file.  If you were doing this
> on
> a blank disk, the first overview for the first file would probably need to
> go after the 2,774th file, etc. since the overviews are relatively big
> compared to your likely block size (if your files are 400MB those
> overviews
> will be 375MB).  2,774 files of 400MB each means that your first overview
> is
> over one terabyte away - that's a LONG seek.  And then you'll have to go
> back for the next header, then back to the overview, etc.
> I presume you don't have a single 7200 RPM ATA drive holding your 2
> terabytes of imagery <g>, but you get the idea.  Jumping around among a
> lot
> of files is a very time-consuming thing to do.  Using GDAL to mosaic those
> file overviews together is an excellent idea.  Instead of 2,774 files of
> 25MB each (for the 16x overview), an arrangement with 174 files of 400MB
> each will very likely be nearly 16 times faster.
>     - Ed
> Ed McNierney
> Chief Mapmaker
> TopoZone.com
> 73 Princeton Street, Suite 305
> North Chelmsford, MA  01863
> Phone: (978) 251-4242
> Fax: (978) 251-1396
> ed at topozone.com
>> From: Frank Warmerdam <warmerdam at POBOX.COM>
>> Reply-To: Frank Warmerdam <warmerdam at POBOX.COM>
>> Date: Thu, 12 Jul 2007 14:52:30 -0400
>> Christopher Condit wrote:
>>> I've got a fairly large set of .tif files (A total of 2774 images at
>>> roughly 400mgs each). They've all had gdaladdo run (at 2 4 8 16), and
>>> then a tile index created. If I attempt to draw the map with mapserver
>>> at the full extents, the cgi request times out. I realize this is too
>>> much data, but the question is: how do I find out at what point the tile
>>> index will break down and overview should be used? Also, if MapServer
>>> won't draw the composite image, will shp2image work?
>>> This is running on a linux machine with 4 2.8 ghz Pentiums and 4gb
>>> RAM...
>> Chris,
>> Mapserv *should* work if given enough time but for a full overview image
>> processing through 2700 files still takes quite a while.  Likewise
>> shp2img should work.  The operational solution is to create a low
>> resolution
>> mosaiced layer all in one file and use MINSCALE/MAXSCALE on the layers to
>> switch between the tileindex layer and the overview layer at appropriate
>> scales.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | President OSGeo,
>> http://osgeo.org
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
