Problems with Mapserver 5
thomas bonfort
thomas.bonfort at GMAIL.COM
Wed Oct 17 11:43:37 EDT 2007
José,
TRANSPARENCY 0 has been deprecated in 5.0 and been replaced with
OPACITY. and a layer with 0 opacity being fully transparent, it is not
drawn.
tb
On 10/17/07, José Ramón López <joseramonlopez at gmail.com> wrote:
> Hi list.
> Im trying to configure mapserver with Oracle Spatial or OCI connection
> This is my layer:
> LAYER
> NAME CARRETERAS
> TYPE LINE
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION " OCI:sde/password at SDE"
> DATA "SDE.RED_CARRETERAS"
> DUMP TRUE
> DEBUG ON
> PROCESSING "CLOSE_CONNECTION=DEFER"
> TRANSPARENCY 0
> PROJECTION
> "init=epsg:23030"
> END
> CLASS
> STYLE
> COLOR 0 0 0
> END
> NAME 'Carreteras'
> END
> METADATA
> "wms_title" "Red Carreteras"
> "wms_keywordlist" "WMS Carreteras"
> "wms_srs" "epsg:23030"
> "wms_extent" "164590 4062740 579080 4266350"
> END
> END
> Mapserver allways send to me a blank image.
> I'd use shp2img , and allways send me a blank image, with this command:
> C:\ms4w-v5\tools\mapserv>shp2img.exe -m c:\ms4w-v5\maps\map\wms.map -i png
> -o C:\test.png -all_debug 9 -l CARRETERAS
> msDrawMap(): Layer 1 (CARRETERAS), 0.000s
> msDrawMap(): Drawing Label Cache, 0.000s
> msDrawMap() total time: 0.000s
> msFreeMap(): freeing map at 0144B390.
> and made some test for testing oracle connection with og2info, and works
> correctly, like:
> C:\ms4w-v5\tools\mapserv>ogrinfo.exe OCI:sde/password at SDE:sde.RED_CARRETERAS
> -SO
> INFO: Open of `OCI:sde/sde at SDE:sde.RED_CARRETERAS'
> using driver `OCI' successful.
> 1: sde.RED_CARRETERAS
> if i use the command with -al option, it sends to me all information
> allocated in this layer.
> Is the problem related with system enviroment?
> In httd.conf:
> SetEnv PATH "C:/Oracle/oracle10g/BIN"
> SetEnv TNS_ADMIN "C:/Oracle/oracle10g/NETWORK/ADMIN"
> SetEnv ORACLE_SID SDE
> SetEnv ORACLE_BASE "C:/Oracle/oracle10g"
> SetEnv ORACLE_HOME "C:/Oracle/oracle10g"
> SetEnv LD_LIBRARY_PATH "C:\Oracle\oracle10g\LIB"
> and de tnsadmin.ora file
> SDE=
> (DESCRIPTION =
> (ADDRESS_LIST =
> (ADDRESS = (PROTOCOL = TCP)(HOST = 172.19.133.19)(PORT = 1521))
> (CONNECT_DATA =
> (SERVICE_NAME = sde)
> Windows 2003 System Enviroment:
> Path=\ms4w\Apache\cgi-bin;\ms4w\tools\gdal-ogr;\ms4w\tools\mapserv;\ms4w\tools\shapelib;\ms4w\proj\bin;\ms4w\tools\shp2tile;\ms4w\tools\shpdiff;\ms4w\tools\avce00;C:\oracle\Oracle10g\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
> PROJ_LIB=\ms4w-v5\proj\nad
> ORACLE_HOME=C:\oracle\Oracle10g
> In ms_erro.txt file nothing is registered.
> Thxs
