wfs geometry property element order
Rushforth, Peter prushfor at NRCAN.GC.CA
Wed Oct 17 12:21:04 EDT 2007
Hi Tom,
Thanks for the response.
Some of the CGDI interoperability pilot project participants are using
MapServer.
We established an application schema based on the geobase.ca RoadSegment
content model, which uses an xsd:sequence of property elements.
Cheers,
Peter
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> Kralidis,Tom [Burlington]
> Sent: October 17, 2007 12:00
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] wfs geometry property element order
> Peter,
> Not that I know of.  You could (could) run the process
> through a WxS process, but that would be a bit of work.  Or
> you could try re-ordering your application schema's elements.
> Out of interest. why did you want to do this?  To adhere to
> an app schema?
> ..Tom
> ________________________________
> From: UMN MapServer Users List on behalf of Rushforth, Peter
> Sent: Wed 17-Oct-07 10:05
> Subject: [UMN_MAPSERVER-USERS] wfs geometry property element order
> Hi,
> We are trying to follow an application schema with the
> mapserver wfs component.  Our source is shapefiles.  We can
> re-order property elements simply by reordering the columns
> in the shapefile, but because the SHAPE column is always
> first in the shapefile, we can't re-order the geometry
> property to where we want it according to the schema.  Is
> there a workaround for this problem?
> Thanks,
> Peter Rushforth
> Technology Advisor / Conseiller technique GeoConnections /
> GéoConnexions
> 650-615 Booth St. / rue Booth
> Ottawa ON K1A 0E9
> E-mail / Courriel: Peter.Rushforth at NRCan.gc.ca Phone /
> Télephone: (613) 943-0784 Fax / telecopier:  (613) 947-2410
