mutually exclusive layers in shp2img?
thomas bonfort
thomas.bonfort at GMAIL.COM
Thu Oct 18 02:31:23 EDT 2007
the command line should be like
shp2img -m or_mapfile.map -l "counties random_polys airports_nearby"
-o random_polys.jpg -e $SMALL_AREA_EXTENT
cheers,
tb
On 10/18/07, Webb Sprague <webb.sprague at gmail.com> wrote:
> Could someone tell me why I can't get both triangles airports AND my
> "random polys" to display in the same map? If I want to see my
> random_polys I have to leave out the "-l airports_nearby" in the
> command.
> I can send pictures if necessary, but will hold off for now.
> Thx
> Command:
> shp2img -m or_mapfile.map -l counties -l random_polys -l
> airports_nearby -o random_polys.jpg -e $SMALL_AREA_EXTENT
> Mapfile:
> MAP
> NAME ORCounties
> SIZE 1200 1200
> IMAGECOLOR 180 180 250
> IMAGETYPE PNG
> UNITS FEET
> EXTENT 183000 88000 2346000 1676000 # Derived from bbox of
> collect of all the counties
> #POLYGON((464233.4375 1145386.125,
> # 464233.4375 1481634,1014976.6875
> 1481634,1014976.6875 1145386.125,464233.4375 1145386.125))
> #EXTENT 460000 1140000 1016000 1483000 # 4 Portland
> counties bbox plus
> FONTSET "./fonts.list"
> WEB
> IMAGEPATH "/tmp/"
> IMAGEURL "/tmp/"
> END
> SYMBOL
> NAME "triangle"
> TYPE vector
> POINTS
> 0 4
> 2 0
> 4 4
> 0 4
> END
> END
> LAYER
> NAME "counties"
> CONNECTIONTYPE postgis
> CONNECTION "user=wsprague dbname=or_gis host=localhost"
> DATA "the_geom from counties" #Note - a space before
> the end quote messes everything up
> STATUS DEFAULT
> TYPE POLYGON
> TRANSPARENCY 25
> LABELITEM "county_nam"
> CLASS
> OUTLINECOLOR 1 1 1
> COLOR 205 92 82
> LABEL
> COLOR 1 1 1
> TYPE TRUETYPE
> SIZE 10
> FONT "arial3"
> END
> END
> END
> LAYER
> NAME "collected_counties"
> DATA "the_geom from collected_counties" #Note - a
> space before the end quote messes everything up
> TYPE POLYGON
> TRANSPARENCY 50
> CLASS
> OUTLINECOLOR 0 0 0
> COLOR 205 205 205
> END
> END
> LAYER
> NAME "random_polys"
> DATA "the_geom from random_polys"
> TYPE POLYGON
> TRANSPARENCY 50
> CLASS
> OUTLINECOLOR 1 1 1
> COLOR 205 205 205
> END #end class
> END # end layer
> LAYER
> NAME "airports"
> DATA "the_geom from airports_view"
> TYPE POINT
> LABELITEM "name"
> LABELCACHE ON
> CLASS
> NAME "LocationSymbol"
> SYMBOL "triangle"
> COLOR 20 20 20
> LABEL
> COLOR 1 1 1
> TYPE TRUETYPE
> SIZE 8
> FONT "arial3"
> POSITION cc
> ANGLE AUTO
> PARTIALS FALSE
> END #end label
> END #end class
> END # end layer
> LAYER
> NAME "airports_nearby"
> DATA "the_geom from airports_nearby"
> TYPE POINT
> LABELITEM "name"
> LABELCACHE ON
> CLASS
> SYMBOL "triangle"
> COLOR 20 90 80
> LABEL
> COLOR 1 1 1
> TYPE TRUETYPE
> SIZE 8
> FONT "arial3"
> #POSITION cc
> #ANGLE AUTO
> #PARTIALS FALSE
> END #end label
> END #end class
> END # end layer
> LAYER
> NAME "hwys"
> DATA "the_geom from hwys2006"
> TYPE LINE
> CLASS
> COLOR 100 100 82
> MINSIZE 4
> END
> END
> LAYER
> NAME "shiptracks"
> DATA "the_geom from shiptracks"
> TYPE LINE
> CLASS
> COLOR 100 100 82
> MINSIZE 4
> END
> END
