Solaris AGG Compile...
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Thu Oct 18 16:26:24 EDT 2007
Well, I've still been unable to get a completely successful install of
MapServer w/ AGG. Interestingly enough the 'mapserv' binary builds, my
failure happens when trying to build 'php_mapscript.so'. I don't have
time now to try and troubleshoot this some more. I'm just going to have
to revert to using GD for the time being. It seems strange however that
the 'mapserv' binary compiles but the php module doesn't, almost seems
like a bug in the php module compile, who knows. If anyone else has some
suggestions for a Solaris 10 compile for MapServer 5/AGG let me know.
Thanks.
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Schlagel, Joel D ERDC-CRREL-NH
> [mailto:Joel.D.Schlagel at erdc.usace.army.mil]
> Sent: Wednesday, October 17, 2007 5:07 PM
> To: Pete Schmitt
> Cc: Nolte, Tim; Smith, Michael ERDC-CRREL-NH
> Subject: FW: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
> Pete,
> possibly you can get in touch with these folks as you work
> to build our
> 5.0 solaris distribution, and see if you can offer or receive
> some support.
> Not sure how far along you are but I would like to be able to
> complete and
> share more widely as nice a 5.0 package as we had for earlier
> versions.
> Thanks
> Joel
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Nolte, Tim
> Sent: Wednesday, October 17, 2007 4:37 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
> Trent,
> Initially it looked this it was going to work. AGG compiled
> without any
> errors and then I tried the MapServer compile only to fail
> when trying to
> compile php_mapscript.so, mapserv compiled without error so
> I'm a little
> confused with that. I'm not sure if there is a bug to address
> here. I did
> have to use 'CC = gcc' instead of 'CC = cc' to get the
> compile to work. I'm
> really hoping that I might be able to figure out some
> solutions so that I can
> get back to using AGG. I'm almost thinking it would have been
> better to just
> go with HostGIS on this server rebuild. Was there any other
> things you had to
> do with your compile of AGG or MapServer? I'm wondering what
> compile options
> others have used successfully on Solaris?
> Is there anyone else out there currently running MapServer 5
> on Solaris, and
> what version of Solaris?
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> From: Trent Erickson [mailto:trente at umn.edu]
> Sent: Wednesday, October 17, 2007 2:40 PM
> To: Nolte, Tim
> Here is a copy of my Makefile.in.SunOS. If this works for you
> let me know and
> I will make a mapserver bug report or a doc somewhere on
> mapserver. I could
> also contact the AGG people and get an alternate
> Makefile.in.SunOS. I'm
> running this on Solaris 9, if this works for you on Solaris
> 10 its likely an
> issue others are struggling with.
> ---- Makefile.in.SunOS start ----
> AGGLIBS= -lagg
> AGGCXXFLAGS = -O3 -I/usr/openwin/include -L/usr/openwin/lib
> CXX = g++
> C = cc
> LIB = ar cr
> .PHONY : clean
> ---- Makefile.in.SunOS end ----
> good luck
> -Trent
> Nolte, Tim wrote:
> > OK, I'm still struggling here. Here is how I modified my
> > Makefile.in.SunOS:
> > Changed:
> > CXX = CC
> > To:
> > CXX = gcc
> > Changed:
> > C = cc
> > To:
> > C = gcc
> > Added:
> > AR = ar
> > LD = ld
> > Changed:
> > LIB = CC -xar -o
> > To:
> > LIB = g++ -xar -o
> > I've also made the change of renaming /usr/ccs/bin/ld to
> > /usr/ccs/bin/ld-off during the AGG build process. Here is what I'm
> > getting as output:
> > cd src; make
> > make[1]: Entering directory `/usr/local/agg-2.4/src'
> > g++ -c -O3 -I/usr/openwin/include -L/usr/openwin/lib
> -I../include -L./
> > agg_arc.cpp -o agg_arc.o
> -I../include -L./
> > agg_arrowhead.cpp -o agg_arrowhead.o
> -I../include -L./
> > agg_bezier_arc.cpp -o agg_bezier_arc.o
> -I../include -L./
> > agg_bspline.cpp -o agg_bspline.o
> -I../include -L./
> > agg_curves.cpp -o agg_curves.o
> -I../include -L./
> > agg_vcgen_contour.cpp -o agg_vcgen_contour.o
> -I../include -L./
> > agg_vcgen_dash.cpp -o agg_vcgen_dash.o
> -I../include -L./
> > agg_vcgen_markers_term.cpp -o agg_vcgen_markers_term.o
> -I../include -L./
> > agg_vcgen_smooth_poly1.cpp -o agg_vcgen_smooth_poly1.o
> -I../include -L./
> > agg_vcgen_stroke.cpp -o agg_vcgen_stroke.o
> -I../include -L./
> > agg_vcgen_bspline.cpp -o agg_vcgen_bspline.o
> -I../include -L./
> > agg_gsv_text.cpp -o agg_gsv_text.o
> -I../include -L./
> > agg_image_filters.cpp -o agg_image_filters.o
> -I../include -L./
> > agg_line_aa_basics.cpp -o agg_line_aa_basics.o
> -I../include -L./
> > agg_line_profile_aa.cpp -o agg_line_profile_aa.o
> -I../include -L./
> > agg_rounded_rect.cpp -o agg_rounded_rect.o
> -I../include -L./
> > agg_sqrt_tables.cpp -o agg_sqrt_tables.o
> -I../include -L./
> > agg_embedded_raster_fonts.cpp -o agg_embedded_raster_fonts.o
> -I../include -L./
> > agg_trans_affine.cpp -o agg_trans_affine.o
> -I../include -L./
> > agg_trans_warp_magnifier.cpp -o agg_trans_warp_magnifier.o
> -I../include -L./
> > agg_trans_single_path.cpp -o agg_trans_single_path.o
> -I../include -L./
> > agg_trans_double_path.cpp -o agg_trans_double_path.o
> -I../include -L./
> > agg_vpgen_clip_polygon.cpp -o agg_vpgen_clip_polygon.o
> -I../include -L./
> > agg_vpgen_clip_polyline.cpp -o agg_vpgen_clip_polyline.o
> -I../include -L./
> > agg_vpgen_segmentator.cpp -o agg_vpgen_segmentator.o
> -I../include -L./
> > ctrl/agg_cbox_ctrl.cpp -o ctrl/agg_cbox_ctrl.o
> -I../include -L./
> > ctrl/agg_gamma_ctrl.cpp -o ctrl/agg_gamma_ctrl.o
> -I../include -L./
> > ctrl/agg_gamma_spline.cpp -o ctrl/agg_gamma_spline.o
> -I../include -L./
> > ctrl/agg_rbox_ctrl.cpp -o ctrl/agg_rbox_ctrl.o
> -I../include -L./
> > ctrl/agg_slider_ctrl.cpp -o ctrl/agg_slider_ctrl.o
> -I../include -L./
> > ctrl/agg_spline_ctrl.cpp -o ctrl/agg_spline_ctrl.o
> -I../include -L./
> > ctrl/agg_scale_ctrl.cpp -o ctrl/agg_scale_ctrl.o
> -I../include -L./
> > ctrl/agg_polygon_ctrl.cpp -o ctrl/agg_polygon_ctrl.o
> -I../include -L./
> > ctrl/agg_bezier_ctrl.cpp -o ctrl/agg_bezier_ctrl.o gcc -c -O3
> > -I/usr/openwin/include -L/usr/openwin/lib -I../include -L./
> > ../gpc/gpc.c -o ../gpc/gpc.o
> > g++ -xar -o libagg.a agg_arc.o agg_arrowhead.o agg_bezier_arc.o
> > agg_bspline.o agg_curves.o agg_vcgen_contour.o agg_vcgen_dash.o
> > agg_vcgen_markers_term.o agg_vcgen_smooth_poly1.o
> agg_vcgen_stroke.o
> > agg_vcgen_bspline.o agg_gsv_text.o agg_image_filters.o
> > agg_line_aa_basics.o agg_line_profile_aa.o agg_rounded_rect.o
> > agg_sqrt_tables.o agg_embedded_raster_fonts.o agg_trans_affine.o
> > agg_trans_warp_magnifier.o agg_trans_single_path.o
> > agg_trans_double_path.o agg_vpgen_clip_polygon.o
> > agg_vpgen_clip_polyline.o agg_vpgen_segmentator.o
> > ctrl/agg_gamma_ctrl.o ctrl/agg_gamma_spline.o ctrl/agg_rbox_ctrl.o
> > ctrl/agg_slider_ctrl.o ctrl/agg_spline_ctrl.o ctrl/agg_scale_ctrl.o
> > ctrl/agg_polygon_ctrl.o ctrl/agg_bezier_ctrl.o ../gpc/gpc.o
> > g++: language ar not recognized
> > /usr/local/lib/gcc/i386-pc-solaris2.10/3.4.6/crt1.o: In function
> > `_start':
> > crt1.s:(.text+0x5c): undefined reference to `main'
> > collect2: ld returned 1 exit status
> > make[1]: *** [all] Error 1
> > make[1]: Leaving directory `/usr/local/agg-2.4/src'
> > make: *** [src/libagg.a] Error 2
> > Any thoughts, anyone? Thanks.
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS: 616-706-2438
> > Fax: 616-554-6484
> > Sent: Tuesday, October 16, 2007 9:45 PM
> > To: Nolte, Tim
> > Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> > The sunfreeware gcc package is compiled with
> --with-ld=/usr/ccs/bin/ld
> > so it can be hard to get around it. (you can see this by running g++
> -v)
> > The sun ld version did not want to compile agg for me. I ended up
> > renaming /usr/ccs/bin/ld to /usr/ccs/bin/ld-off I then
> put it back
> > after the compile. This of course requires root access.
> > It is not very elegant but it worked. If anyone has any other
> > suggestions I'd love to know how to force the proper ld
> with resorting
> > to this. It just plain ignored the makefile and environment
> settings.
> > -Trent
> > Nolte, Tim wrote:
> >> OK, well here's my setup. I have the following sunfreeware packages
> >> installed:
> >> gcc-3.4.6-sol10-x86-local
> >> make-3.81-sol10-x86-local
> >> automake-1.10-sol10-x86-local
> >> libtool-1.5.24-sol10-x86-local
> >> I've set my PATH environment to use '/usr/local/bin' before
> >> '/usr/ccs/bin'. And my g++/gcc/make/ar/ld are all GNU when I run
> > 'type'
> >> on them. I did notice that gcc reports (Configured with:
> ../configure
> >> --with-as=/usr/ccs/bin/as --with-ld=/usr/ccs/bin/ld --enable-shared
> >> --enable-languages=c,c++,f77) so I'm not sure if this would be an
> > issue.
> >> Thanks for any other thoughts.
> >> iPCS Wireless, Inc.
> >> Kentwood, MI 49512
> >> PCS: 616-706-2438
> >> Fax: 616-554-6484
