mapscript point layer zooming
Fanda
zerosgm at GMAIL.COM
Fri Oct 19 03:19:18 EDT 2007
Hi Tamas,
I've tried to render the map with drawmap but it behaves exactly the same as
my app. I submit all the needed data with this message. I put both the
extents (full view and zoomed view when the layer 'vrty' doesn't show up) in
the mapfile definition.
Best regards,
Fanda
Tamas Szekeres wrote:
> Hi,
> You might want to test with the drawmap C# sample (can be found in the
> ms4w package as well) to see whether the application can draw the
> layer with the same extent. (set the extent of the map in the mapfile
> accordingly).
> If drawmap behaves the same, then submit a ticket with your data file
> along with the mapfile for tracking down the problem.
> Best regards,
> Tamas
> 2007/10/17, Fanda <zerosgm at gmail.com>:
>> I am using the latest version of mapserver (ms4w 2.2.6), c# mapscript. I
>> don't know exactly what inline layer means, but I don't think that's the
>> case of my layer. I've attached the whole mapfile to this message (the
>> point
>> layer is the very last one called 'Vrty'). It shows up in full extent,
>> but
>> as I pan or zoom so that any point of the layer is outside the current
>> extent, the whole layer disappears.
>> Best regards,
>> Fanda
>> > Hi,
>> > It would be helpful to post the entire mapfile you have. Are you using
>> > an inline layer as the point layer?
>> > Which projection you use with your map? What is the mapserver version?
>> > Best regards,
>> > Tamas
>> > 2007/10/16, Fanda <zerosgm at gmail.com>:
>> >> Hi all,
>> >> I am facing really odd problem. I have some line and polygon layers in
>> my
>> >> mapfile and everything goes fine with them. But there is also one
>> POINT
>> >> layer and it shows up only in its full extent. If I zoom in or pan the
>> >> layer
>> >> disappears whereas the other layers are still visible as expected.
>> There
>> >> is
>> >> no max/minscale defined. I am using C# mapscript. The definition of
>> the
>> >> layer in the mapfile is as follows:
>> >> LAYER
>> >> NAME Vrty
>> >> STATUS ON
>> >> TYPE POINT
>> >> DATA "vrty"
>> >> TOLERANCE 1
>> >> CLASS
>> >> NAME 'vrty'
>> >> STYLE
>> >> SYMBOL 'circle'
>> >> SIZE 20
>> >> COLOR 255 0 0
>> >> END
>> >> END
>> >> PROJECTION
>> >> "init=epsg:2065"
>> >> END
>> >> END
>> >> Any help would be greatly appreciated,
>> >> Fanda
>> >> View this message in context:
>> http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13229010
>> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> http://www.nabble.com/file/p13247791/mapa.map mapa.map
>> http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13247791
http://www.nabble.com/file/p13289551/data.zip data.zip
View this message in context: http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13289551
