GMapFactory: creating interactive map without ROSA Java applet?
Paul Scott pscott at UWC.AC.ZA
Fri Oct 19 04:36:52 EDT 2007
On Fri, 2007-10-19 at 01:32 -0700, kreshna_iceheart at yahoo.com wrote:
> Alas, I also discovered that it uses ROSA Java applet,
> while here in Indonesia, applet is a big no-no because
> there's still a lot of users with older browsers
> withou Java plugin.
You may want to take a look at mscross, which is an AJAX based script
that does the same stuff as ROSA.
I am struggling with it at the moment, so if you need help, I can
probably guide you as well.
BTW, is mscross still in the limelight? or am I barking up the wrong
tree?
--Paul
All Email originating from UWC is covered by disclaimer http://www.uwc.ac.za/portal/uwc2006/content/mail_disclaimer/index.htm
