Mapscript srs resetting
Marcos Sánchez Provencio marcos at BURKE.ATH.CX
Fri Oct 19 08:10:00 EDT 2007
Raster layers seem to reproject fine :-O Could it be some kind of
optimsation? This is the version I am using (it comes with ubuntu 6.06)
simif at webdgb2:~/src/simif$ mapserv -v
MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
El vie, 19-10-2007 a las 14:00 +0200, Marcos Sánchez Provencio escribió:
> I have to serve data stored in utm30 and utm28 (Continental Spain and
> the Canary Islands) reprojected to utm30 (Continental Spain except
> Galicia), utm29(Galicia) and utm28(Canary Islands).
> I am creating the map from scratch in Python mapscript. The client is
> mapbuilder wms. I am setting the map projection for each query with
> setProjection. If I start the server and immediatly ask for utm29 it
> works fine. Then I ask for utm30 and it works fine too. I ask again for
> utm29 and it shows utm30 (some shapes not shown). But if I then ask for
> the utm28 map, it shows fine :-S
> The server is the django test server (to rule out threading/process
> problems).
> Any suggestions?
