MySql error message
Anakreon Mentis
anakreon at CSD.AUTH.GR
Mon Oct 22 12:26:47 EDT 2007
Kyle Wilcox writes:
> Make sure your connection is not timing out and you are not closing the
> connection anywhere.
Thanks for your reply.
I have created the ovf file from examples found in the internet.
The content of the file is:
<OGRVRTDataSource>
<OGRVRTLayer name="sites">
<SrcDataSource>MYSQL:db_test,user=user,password=pswd,host=localhost,port=3306,tables=site coordinate</SrcDataSource>
<SrcSQL>
select site_name, c1.cord_deg + (c1.cord_min / 60) + (c1.cord_sec /600) as x,
c2.cord_deg + (c2.cord_min / 60) + (c2.cord_sec /600) as y
from site
inner join coordinate as c1 on c1.coordinate_id = site.coordinate_first
inner join coordinate as c2 on c2.coordinate_id = site.coordinate_second
</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Perhaps there is a timeout parameter?
I have not specified any timeout myself.
The data are displayed using pmapper. I do not know if pmapper closes
the connection.
I'd appriciate if you could send me a link to the ovf file specification.
I had found once a link (at the mapserver.gis.umn.edu I think) but it
did not work.
> Anakreon Mentis wrote:
> > From a layer, I show data which are retrived by a query
> > to a mysql database.
> > The problem is that sometime, map server reports an error
> > with message:
> > [MapServer Error]: msOGRFileNextShape(): MySQL error message:MySQL server has gone away
> > What is going wrong?
