Postgres Raster image display
Brent Fraser bfraser at GEOANALYTIC.COM
Tue Oct 23 12:21:59 EDT 2007
Ryan,
  You've got TILEINDEX and TILEITEM  swapped.  They should
be:
  TILEITEM "location"
  TILEINDEX "stereo_simp"
TILEINDEX is the name of the layer in the map file defining
the tileindex geometry,  TILEITEM is the attribute field in
that layer showing the location of the raster files.
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
From: "Ryan Ollerenshaw" <ryanollerenshaw at GMAIL.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, October 22, 2007 3:52 PM
Subject: Re: [UMN_MAPSERVER-USERS] Postgres Raster image
display
> On 10/22/07, Paul Ramsey <pramsey at refractions.net> wrote:
> > Answer here?
http://mapserver.gis.umn.edu/docs/howto/wms_time_support/#example-of-
> > wms-t-with-postgis-tile-index-for-raster-imagery
> I gave it a try but i keep getting the error:
>  msSHPOpenFile(): Unable to access file.
(/var/www/html/data/location)
> here is what i changed by map file too:
> LAYER
>   NAME "stereo_simp"
>   TYPE POLYGON
>   STATUS on
>   CONNECTION "host=localhost dbname=mars user=postgres"
>   CONNECTIONTYPE POSTGIS
>   #DATA
"/hiview/products/data_sun/20070929_000600_14euA_171_16_gdal
.tif"
>   DATA "the_geom FROM usgs_gaz"
> END
> LAYER
>   NAME "stereo_test"
>   STATUS on
>   TYPE RASTER
>   PROCESSING "SCALE=AUTO" #rescale 16-bit to 8-bit
>   PROJECTION
>     "init=epsg:4326"
>   END
>   DUMP TRUE
>   METADATA
>    wms_title "USGS Gazetteer Place Names" ## REQUIRED
>    wms_srs "EPSG:4326"
>   END
>   TILEINDEX "location"
>   TILEITEM "stereo_simp"
> END  # layer
> whenever i use the tag TILEINDEX is always looks for a
file, in my
> case a file /var/www/html/data/location.  Why cant i get
this to grab
> the path in the database that contains the location of the
file?
> > On 22-Oct-07, at 2:28 PM, Ryan Ollerenshaw wrote:
> > > On 10/22/07, Ryan Ollerenshaw
<ryanollerenshaw at gmail.com> wrote:
> > >> How can i use a Postgres database to display raster
images with
> > >> Mapserver?  There are lots of examples on display
features this way
> > >> and using a gdaltindex to create a shapefile but i
cant find any that
> > >> talk about using a database to store raster images.
Here is what
> > >> i am
> > >> currently trying:
> > >> LAYER
> > >>   NAME "stereo_simp"
> > >>   TYPE RASTER
> > >>   PROCESSING "SCALE=AUTO" #rescale 16-bit image to
8-bit
> > >>   STATUS on
> > >>   CONNECTION "host=localhost dbname=test
user=postgres"
> > >>   DATA "location FROM stereo"
> > >>   TILEINDEX "stereo" #the table name
> > >>   TILEITEM "location" #column that contains the path
to the image
> > >> END
> > >> if i just try and display the image directly it works
just fine:
> > >> LAYER
> > >>   NAME "stereo_simp"
> > >>   TYPE RASTER
> > >>   STATUS on
> > >>   DATA
"/hiview/products/data/20070929_000600_14euA_171_16_gdal.tif
> > >> END
> > > Sorry i should have been more clear on my post I do
not want to store
> > > the images directly in the database, what i am trying
to do is store
> > > the location of the image in the database and use
mapserver to read
> > > this location column and display the image.  This
works fine when
> > > using gdaltindex when gdal generates the dbf file for
example using
> > > this technique:
> > > LAYER
> > >   NAME "stereo_simp"
> > >   TYPE RASTER
> > >   STATUS on
> > >   TILEINDEX "images.shp"
> > >   TILEITEM "location"
> > > END
> > > but when i try to use Postgres as the TILEINDEX this
does not work,
> > > ie:
> > > LAYER
> > >   NAME "stereo_simp"
> > >   TYPE RASTER
> > >   STATUS on
user=postgres"
> > >   TILEINDEX "the_geom FROM stereo"
> > >   TILEITEM "location"
> > > END
> > >   any ideas on what i am doing wrong?
