shp2img: free(): invalid next size
Ryan Ollerenshaw
ryanollerenshaw at GMAIL.COM
Tue Oct 23 15:08:15 EDT 2007
On 10/23/07, Kyle Wilcox <Kyle.Wilcox at noaa.gov> wrote:
> Are you compiling 4.10 the same way you did 4.8.3? Same GD/OGR?
Yes, everything in my configure command is the same.
> Ryan Ollerenshaw wrote:
> > During my Mapserver install i get an error that says unable to
> > location ogr_api.h in map.h so i then have to go in and edit map.h to
> > specify the location of ogr_api.h by hand. Then on the next run of
> > make i get the error unable to locate cpl_minixml.h in mapogcsld.h so
> > i then have to add the path to cpl_minixml.h in mapogcsld.h by hand as
> > well. After this the make seems to run fine, except for the warnings:
> > php_mapscript.c: In function ‘php3_ms_img_pasteImage’:
> > php_mapscript.c:6320: warning: implicit declaration of function
> > ‘php_gd_gdImageColorExact’
> > php_mapscript.c:6324: warning: implicit declaration of function
> > ‘php_gd_gdImageColorTransparent’
> > php_mapscript.c:6327: warning: implicit declaration of function
> > ‘php_gd_gdImageCopy’
> > after the make is complete when i try to run shp2img i get the error:
> > *** glibc detected *** ./shp2img: free(): invalid next size (fast):
> > 0x08564e00 ***
> > ======= Backtrace: =========
> > /lib/i686/nosegneg/libc.so.6[0x1ee2c8d]
> > /lib/i686/nosegneg/libc.so.6(cfree+0x90)[0x1ee6340]
> > I am trying to install Mapserver 4.10.3 on fedora core 6. I have
> > Mapserver 4.8.4 installed and running just fine but i need the WMS
> > time Support that was added in 4.9 and up, so i need this new install
> > to work. Any ideas on what has changed between versions 4.8 and 4.10
> > that would cause these errors?
> Kyle Wilcox
> NOAA Chesapeake Bay Office
> 410 Severn Avenue
> Suite 107A
> Annapolis, MD 21403
> office: (410) 295-3151
> "It is from the wellspring of our despair and the places
> that we are broken that we come to repair the world."
> - Murray Waas
