WFS iso-8859-1 to utf-8
Arnd Wippermann
arndw at WTAL.DE
Fri Oct 26 09:04:19 EDT 2007
after the release of OpenLayers 2.5 I have looked at WFS. Loading the
geometry with OpenLayers from MapServer works. But to retrieve the
attributes in the right way (utf-8) is in some way difficult.
For IIS I have found a solution, that takes input in i.e "ISO-8859-1" and
creates UTF-8.
I use a wrapper-script, that 1. hides the real OnlineResource and 2. convert
the input to utf-8.
The script (ported to vbscript) can also used to convert local xml-files to
utf-8.
Perhaps someone have an idea to do this in python or php for the use with
apache. I have no clue, how to do this.
Option Explicit
'usage : http://this.asp 'without parameter the xmlString will converted
and send to the browser
'or http://this.asp?WFS-Parameter
Dim strRequest
Select Case Request.ServerVariables("REQUEST_METHOD")
Case "GET" strRequest = Request.QueryString
Case "POST" strRequest = Request.Form
End Select
Call Haurein
Sub haurein()
Dim testLocal
if strRequest = "" then
testLocal = true
else
testLocal = false
end if
Dim xmlString 'for local test
xmlString = "<?xml version=""1.0""
encoding=""ISO-8859-1""?>" & vbCrLf
xmlString = XMLString & "<document>" & vbCrLf
xmlString = XMLString & " <tagOne>ein Ä - ä, Straße,
Überlauf</tagOne>" & vbCrLf
xmlString = XMLString & " <tagOne>ein Ö - ö</tagOne>" & vbCrLf
xmlString = XMLString & " <tagOne>ein Ü - ü # é, á</tagOne>" &
vbCrLf
xmlString = XMLString & " <tagOne>#ä#ö#ü#ß - Ä#Ö#Ü#</tagOne>" &
vbCrLf
xmlString = XMLString & "</document>" & vbCrLf
Dim mapserv, strURL
if testLocal = false then
mapserv = "http://[mapserv.exe]?map=[mapfile]"
strURL = mapserv & "&" & strRequest
end if
'response.write strURL
'Create new XML object for conversion and load xmlString or request
and load the WFS
Dim oDOM
Set oDOM = Server.CreateObject("Microsoft.XMLDOM")
if testLocal then
oDOM.loadXML(xmlString)
else
Dim objHTTP
Set objHTTP = Server.CreateObject("MSXML2.ServerXMLHTTP")
On Error Resume Next
'get the WFS response
objHTTP.open "GET", URLDecode(strURL), false
if err.number <> 0 then
Response.Write err.description & "<br><b>testLocal</b> : " &
testLocal & "<br><b>mapserv</b> : " & mapserv & "<br><b>strRequest</b> : " &
strRequest
Exit Sub
end if
objHTTP.send ""
'declare the original charset
Response.CharSet = "ISO-8859-1"
Response.ContentType = "text/xml"
oDOM.load(objHTTP.responseXML)
end if
'Replace the processing instruction of the XML object
Dim pi
Set pi = oDOM.createProcessingInstruction("xml", "version=""1.0""
encoding=""utf-8""")
oDOM.replaceChild pi, oDOM.childNodes.item(0)
'declare the charset of the output
Response.CharSet = "UTF-8"
oDOM.save(Response)
Set objHTTP = Nothing
Set oDOM = Nothing
Set pi = Nothing
End Sub
' An inverse to Server.URLEncode
function URLDecode(str)
dim re
set re = new RegExp
str = Replace(str, "+", " ")
re.Pattern = "%([0-9a-fA-F]{2})"
re.Global = True
URLDecode = re.Replace(str, GetRef("URLDecodeHex"))
end function
' Replacement function for the above
function URLDecodeHex(match, hex_digits, pos, source)
URLDecodeHex = chr("&H" & hex_digits)
end function
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
