Bbox in GetCapabilies for PostGIS layer
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Oct 26 09:38:30 EDT 2007
Barend Köbben wrote:
>> I'd suggest that you file a ticket about this.
> Can you point me to the place where I can do such a thing...?
http://trac.osgeo.org/mapserver/
>> I am not sure how easy
>> that will be to fix, since we'll need a way to tell the capabilities
>> generation code that the extent returned by Postgis is not meaningful.
> My suggestion is that the error is in the way you ask the data/extent from
> PostGIS. PostGIS in it's own right is perfectly capable of providing a
> correct extent : SELECT extent(the_geom) FROM test, if you need the
> LatlonBBOX: SELECT transform( extent(the_geom),4326) FROM test. How is
> MapServer requesting the bbox at the moment...?
There is a GetExtents() method on all data providers in MapServer and
the postgis driver seems to have a very poor implementation that just
returns infinite extents to avoid having to do a full table scan which
could be very expensive in some cases.
FYI this ticket discusses the issue and why "select extent() ..." was
not used before:
http://trac.osgeo.org/mapserver/ticket/1851
Daniel
Daniel Morissette
http://www.mapgears.com/
