Mapserver installing error: libgdal.so.1
H. Porath
porath at WEB.DE
Tue Oct 30 04:09:57 EDT 2007
Mirko,
did you try setting LD_LIBRARY_PATH to gdal lib dir before calling mapserv? If this works, ldconfig should work, too. Does "ldconfig -p | grep libgdal" give you a result? If not, check your /etc/ld.so.conf.
Holger
-----Ursprüngliche Nachricht-----
Von: Mirko Zucchetto <mirko.zucchetto at GMAIL.COM>
Gesendet: 29.10.07 15:16:39
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: [UMN_MAPSERVER-USERS] Mapserver installing error: libgdal.so.1
Hi, I'm going to install Mapserver using this document.
I repeat step by step the instructions and comments, but at the end I
have this error message when I test it:
mirko:/usr/local/apache2/cgi-bin# /usr/local/apache2/cgi-bin/mapserv
/usr/local/apache2/cgi-bin/mapserv: error while loading shared
libraries: libgdal.so.1: cannot open shared object file: No such file
or directory
i try to run ldconfig after install gdal and mapserver...
My system on Debian Etch:
-httpd-2.2.6
-postgresql-8.2.5
-php-5.2.4
-proj-4.5.0
-geos-3.0.0rc4
-gdal-1.4.0
-mapserver-5.0.0
Can anyone help me?
Thanks a lot.
Mirko.
_____________________________________________________________________
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
