A really weird problem with querying a map
Gregor Mosheh
gregor at HOSTGIS.COM
Wed Oct 31 16:52:01 EDT 2007
Fawcett, David wrote:
> I think that this behavior is new in 5.0, but I could be wrong.
Could be. I'm using MS 4.10.3
I'm sorry I forgot to mention that earlier.
> It would be interesting to run a test to see if this occurs on a layer
> where the layer and output are the same SRS. (e.g. pre-project your
> data)
I have done this. Reprojecting the data does solve this issue, allowing
me to drop the tolerance and toleranceunits and to have it work just
perfectly.
That's a viable workaround, yes, but if this is a real bug, ...
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
