strange problem with quadtree index
Frank Warmerdam warmerdam at POBOX.COM
Mon Sep 3 13:27:57 EDT 2007
Bart van den Eijnden wrote:
> Hi list,
> I have a 3D POINT shapefile dataset, and if I do a query using Mapserver
> (or ogrinfo for that matter) when the shapefile has a quadtree index
> file associated (level 4), it does not find any features within the box.
> If I delete the qix file, it correctly finds all the features in the
> box, but ofcourse performance is poor.
> Any pointers on this problem? Or is the dataset needed to find out the
> cause of such an issue (it's quite big unfortunately)?
Bart,
Is the problem in mapserver when using the point layer as an OGR layer?
I am not aware of why this would be failing but it certainly sounds like
a serious bug and I'd appreciate your filing a bug report against GDAL/OGR
with supporting data and other details.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
