strange problem with quadtree index
Flavio Hendry
flavio at TYDAC.CH
Tue Sep 4 03:33:49 EDT 2007
Hi Bart
Read this? (I had even MapServer crashing when using default on points):
http://umn.mapserver.ch/MapServer/en/shapetree.htm, on the bottom:
SYNTAX: shptree <shpfile> [<depth>]
<depth> (optional) is the maximum depth of the index to create, default
is 0 meaning that shptree will calculate automatically the default depth
(calculated so, that a quadtree cell contains 8 shapes). Do not use the
default depth with point files, here a depth between 6 and 10 works fine.
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC Web-Site: http://www.tydac.ch
TYDAC MapServer: http://www.mapserver.ch
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Mon, 3 Sep 2007 17:21:46 +0200
Subject: [UMN_MAPSERVER-USERS] strange problem with quadtree index
> Hi list,
> I have a 3D POINT shapefile dataset, and if I do a query using
> Mapserver (or
> ogrinfo for that matter) when the shapefile has a quadtree index file
> associated (level 4), it does not find any features within the box.
> If I delete the qix file, it correctly finds all the features in the
> box,
> but ofcourse performance is poor.
> Any pointers on this problem? Or is the dataset needed to find out
> the cause
> of such an issue (it's quite big unfortunately)?
> Best regards,
> Bart
