blank image
Gregor Mosheh
gregor at HOSTGIS.COM
Tue Sep 4 20:01:37 EDT 2007
Terence Maru wrote:
> Hi everyone, I have a problem generating an image from my postgis
> database I have attached my php script. No errors are returned when
> the script is run, just a blank image is returned. Can anyone see whats
> wrong with my script? Cheers
This exact same question came up two days ago. 90% of the time, the
issue is projections. Ensure that all layers and the output map are in
the same projection, or else set projection blocks. 90% of the time,
that fixes it.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
