SYMBOLSCALE and SLD
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Sep 5 10:56:09 EDT 2007
Bart van den Eijnden wrote:
> Hi list,
> when Mapserver applies an SLD to a LAYER, it does not remove SYMBOLSCALE
> from the LAYER, which results in line widths etc. which do not
> correspond exactly to the SLD line widths.
> Is this intentional? Should it not remove SYMBOLSCALE when applying an SLD?
Not really intentional, I simply never used SYMBOLSCALE in the tests.
It is kind of debatable if the SLD should remove this setting. I am
more inclined at this point to agree with you so that SYMBOLSCALE will
always be set to -1 when the SLD is applied. I have opened
http://trac.osgeo.org/mapserver/ticket/2291 for it so others can comment
on it.
Later,
> Best regards,
> Bart
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
