Can't execute mapserv.exe from Apache 2 cgi-bin folder
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at GMAIL.COM
Thu Sep 6 08:30:10 EDT 2007
you need to include the extension of the mapserver cgi file... you need to
put the ".exe" at the end of your url and it will work (I already try it ;)
http://213.133.227.245/cgi-bin/mapserv.exe
Rodrigo.
On 9/6/07, Francesco Sozzi <fsozzi at intercad.ch> wrote:
> Hi Rodrigo,
> Thanks for help.
> Unfortunatelly I already have the following line:
> ScriptAlias /cgi-bin/ "C:/Programmi/Apache Group/Apache2/cgi-bin/"
> And if I try to run http://213.133.227.245/cgi-bin/mapserv I have a 404
> error (file not found).
> So, I think there is something else wrong...
> I attacched my configuration file.
> Best regards
> Francesco
> ----- Original Message -----
> *From:* Rodrigo Martín LÓPEZ GREGORIO <rodrigomlg at GMAIL.COM>
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Sent:* Thursday, September 06, 2007 1:24 PM
> *Subject:* Re: [UMN_MAPSERVER-USERS] Can't execute mapserv.exe from Apache
> 2 cgi-bin folder
> Hi Francesco
> You also need to have a Script Alias in your httpd.conf file like this:
> ScriptAlias /cgi-bin/ "/ms4w/Apache/cgi-bin/"
> and then (after restarting apache) you can try to access mapserver like:
> http://yourservername:port/cgi-bin/mapserv.exe
> Rodrigo.
> > Hi All,
> > I'm trying to let Mapserver provide as WMS server, but I have an Apache
> > configuration problem.
> > I've put mapserv.exe into C:/Programmi/Apache Group/Apache2/cgi-bin.
> > But I can't execute from browser (it is as it does not see/execute the
> > file).
> > I have no problem in Apache 1.x but I have problem with a standard
> > installation of Apache 2 on Windows XP.
> > In my httpd.conf I have this cgi-bin folder definition:
> > <Directory "C:/Programmi/Apache Group/Apache2/cgi-bin">
> > AllowOverride None
> > Options None
> > Order allow,deny
> > Allow from all
> > </Directory>
> > How can I set execution permission?...
> > Best regards
> > Francesco
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070906/b10943f7/attachment.html
