change <!DOCTYPE WMT_MS_Capabilities SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Sep 6 09:31:45 EDT 2007
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of shortyII
> Sent: 06 September, 2007 9:11 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] change <!DOCTYPE
> Hello,
> to connect my mapserver to my "special" GIS program, I have
> to change the getCapabilities file. Usually the files starts
> with <!DOCTYPE WMT_MS_Capabilities SYSTEM
> http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd",
> but for reason, I don't understand (some connection
> problems), I have to change it to a local path e.g. <!DOCTYPE
> "http://localhost/wms/1.1.1/WMS_MS_Capabilities.dtd".
> I have seen some getCapabilities-files, which have a
> different <!DOCTYPE...>, but i didn't find any files, where I
> could change it.
> Thanks for helping. It is urgent!
> Best regards,
> Stefan Schantz
Sounds like you may be having connection issues Can you get to remote
URL locations?
In MAP/WEB/METADATA/, you can set "ows_schemas_location" (see
http://mapserver.gis.umn.edu/docs/howto/wms_server/#web-object-metadata)
If you set ows_schemas_location, the code will output the correct
location of the DTD as per the main schemas.opengis.net site with the
ows_schemas_location you specify. If you do not specify
ows_schemas_location, the code will use the default definition.
In either case, the DOCTYPE declaration is correctly outputted by the
code.
..Tom
