Point data from SQL Server
Milo van der Linden
mlinden at ZEELANDNET.NL
Mon Sep 10 03:35:58 EDT 2007
Hi Jerry!
The best way to go for you is using a virtual format datasource like
described on:
http://www.gdal.org/ogr/drv_vrt.html
This way you connect to your SQL server database like:
<OGRVRTDataSource>
<OGRVRTLayer name="mypointstable">
<SrcDataSource>ODBC:SQLSERVER CONNECTION</SrcDataSource>
<SrcLayer>worms</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
If this won't work, nothing will!
Kind regards!
Milo van der Linden
> Hi,
> I have point data in SQL Server (X,Y Columns in a table), what is the best
> way to display this in
> mapserver..ideally without having to transform it to another data format.
> Thanks in advance
> Jerry
Milo van der Linden
<a href="http://somafm.com/"><img
src="http://somafm.com/linktous/450x25sfm1.gif" alt="SomaFM" border=0
width=450 height=25 ></a>
