Reg. using Map Server as a viewer
P Kishor
punk.kish at GMAIL.COM
Mon Sep 10 09:42:06 EDT 2007
On 9/10/07, Varun Sahni <logon2varun at yahoo.com> wrote:
> Hi,
> Any help regarding this
A question like this is too basic, and is likely to go unanswered. I
will try and provide an answer below, but that may not be enough for
you.
If you want to use MapServer purely as a viewer, and by that, it seems
to imply that you want to use it as a desktop viewer (one person),
then it is really not the right product. Try looking at QGIS or uDig.
MapServer, as the name implies, is a server, and getting it going
takes a bit more than insignificant work, usually worth it in a server
type demand situation.
Whether or not any of these products can read AutoCad data, look at
the docs. AutoCad data come in many different formats... which one
were you interested in? The docs of any of the above products will
tell you.
As I said above, you will have to look at your own data formats and
then look at the docs of the products you are considering.
Good luck.
> Varun Sahni <logon2varun at YAHOO.COM> wrote:
> Date: Thu, 6 Sep 2007 06:13:32 -0700
> From: Varun Sahni <logon2varun at YAHOO.COM>
> Subject: [UMN_MAPSERVER-USERS] Reg. using Map Server as a viewer
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Hi,
> Does Map Server serves the purpose of a viewer also for files generated by
> AutoCAD?
> If so, what file format it supports?
> Thanks and Regards,
> Varun
> ________________________________
> Yahoo! oneSearch: Finally, mobile search that gives answers, not web links.
> Park yourself in front of a world of choices in alternative vehicles.
> Visit the Yahoo! Auto Green Center.
Puneet Kishor
http://punkish.eidesis.org/
Nelson Institute for Environmental Studies
http://www.nelson.wisc.edu/
Open Source Geospatial Foundation (OSGeo)
http://www.osgeo.org/
Summer 2007 S&T Policy Fellow, The National Academies
http://www.nas.edu/
