Mapserver 5 expressions
Lars-Göran Edholm lged_morris at HOTMAIL.COM
Mon Sep 10 11:45:06 EDT 2007
Hi again.
I still have problem with expressions with 2 or more values.
In Mapserver 4 I use:
...&map_fastvisa_class_expression=([FNR]=210176493 OR [FNR]=210176494)..
In Mapserver 5 I use:
In the Map-file:
EXPRESSION ([FNR]=%fasokex%)
and in the URL
.....&fasokex=210176493&....
but how to use 2 or more values in Mapserver 5??
The whole URL is like:
http://172.20.1.218/cgi-bin/mapserv5b5/mapserv.exe?map=C:\\Iis-Webbplatser\\BoM\\Byggmiljo\\mapserverapps\\ejfonster2007\\BMNStartintra2003cli.map&hussokex=210176493&mapext=1551957+6714299+1552357+6714699&behorig=A,B,N&pixlar=51.6&zoomsize=4&zoomdir=0&layer=Komm&layer=vatt&layer=Vag4&layer=Gatt&layer=regen&layer=polrit&layer=lmvhojd&layer=lmvtext&layer=magro&layer=lmvhus&layer=lmvvatt&layer=lmvkraft&layer=orto&layer=fastvisa&layer=uthus&layer=bohus&mapsize=900+630&layer=pktrit&map_pktrit_feature_points=1552157+6714499&map_pktrit_feature_text=&map.layer[pktrit]=FEATURE+POINTS+1552157+6714499+END+END&program=/cgi-bin/mapserv5b5/mapserv.exe&imgxy=450+315&fasokex=210176493
Lars-Göran Edholm
_________________________________________________________________
Vad händer på modefronten? http://salongk.msn.se/
