5.0: change in PIXMAP SIZE?
Bart van den Eijnden
bartvde at GMAIL.COM
Tue Sep 11 10:08:26 EDT 2007
Something additional, Mapserver does not comply with the SLD spec if you
omit the Size in the SLD. The SLD 1.0 spec says:
"The default size of an image format (such as GIF) is the inherent size of
the image."
but Mapserver seems to use a default of 6 pixels ...
if (psSize && psSize->psChild && psSize->psChild->pszValue)
psStyle->size = atoi(psSize->psChild->pszValue);
else
psStyle->size = 6; /* defualt value */
Best regards,
Bart
On 9/11/07, Bart van den Eijnden <bartvde at gmail.com> wrote:
> Hi list,
> I just spent half of my day finding out why an SLD with external graphics
> did not work anymore with 5.0, something like:
> <PointSymbolizer><Geometry><PropertyName>msGeometry</PropertyName></Geometry><Graphic><ExternalGraphic><OnlineResource
> 'xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="'.$this->externalgraphic.'"/><Format>GIF</Format>'.
> '</ExternalGraphic><Size>1.0
> </Size></Graphic></PointSymbolizer></Rule>
> I used a PointSymbolizer with Size 1 and this results in something like:
> STYLE
> ANGLE 360
> COLOR 0 0 0
> SIZE 1
> SYMBOL "....."
> END
> In Mapserver 4.10 this used to draw the symbol in its native
> size/dimension, but in 5.0 this does not work anymore, i.e. I do not see
> anything in the map.
> If I change Size to 17 (the size in pixels of the image used), the SLD
> works fine again.
> Was this change intentional? Anyways, I guess this should be documented in
> the migration guide :-) ?
> Best regards,
> Bart
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070911/f957e01a/attachment.html
