Mapserver SDE 9.2 Question
Howard Butler hobu.inc at GMAIL.COM
Tue Sep 11 16:26:42 EDT 2007
Josh,
Set MS_ERRORFILE as per MS RFC 28 to get debug output <http://
mapserver.gis.umn.edu/development/rfc/ms-rfc-28>.  When it queries
the REGDIV layer, the SDE debug output should tell you what it thinks
the names of the columns are.  You should be able to then use that
column name for the CLASSITEM.
Howard
On Sep 11, 2007, at 3:09 PM, Josh Hevenor wrote:
> My installation is working well. I really appreciate all your help :)
> I had a quick question about symbolization for SDE layers. I made a
> sample map file based on my applications existing map file. I
> update a couple background layers to use our SDE services. Two of
> three of these layers work well and the third does not draw. This
> third layer (REGDIV) has a CLASSITEM set and a number of CLASSES
> defined. There is no error displayed, even with the -map_debug or -
> all_debug flags set. If I change the layer to use just one default
> class then the layer draws.
> I tried updating my CLASSITEM to use a full path, for example DIVID
> became GIS.DBO.REGDIV.DIVID but I received the following error:
> 	C:\ms4w\apps\sdedemo>shp2img -m gp.map -o gp.png
> 	msDrawMap(): Image handling error. Failed to draw layer named
> 	'REGDIV'. <br>
> 	msSDELayerInitItemInfo(): SDE error. A specified CLASSITEM,
> FILTERITEM, or expression key cannot be found <br>
> My Layer looks like this
> 	LAYER
> 	    NAME 'REGDIV'
> 	    STATUS on
> 	    TYPE POLYGON
> 	    CONNECTIONTYPE PLUGIN
> 	    PLUGIN "c:/ms4w/apache/specialplugins/msplugin_sde_92.dll"
> 	    CONNECTION "matata,port:5252,GIS,sa,sa"
> 	    PROCESSING 'CLOSE_CONNECTION=DEFER'
> 	    DATA "GIS.DBO.REGDIV,Shape,dbo.DEFAULT"
> 	    TOLERANCE 12
> 	    TRANSPARENCY 75
> 	    CLASSITEM 'GIS.DBO.REGDIV.DIVID'
> 	    CLASS
> 	      NAME 'West'
> 	      EXPRESSION 'West'
> 	      TEMPLATE 'null'
> 	      STYLE
> 	        COLOR 204 204 204
> 	        OUTLINECOLOR 5 5 5
> 	      END  #STYLE
> 	    END #CLASS
> 	    CLASS
> 	      NAME 'Ontario'
> 	      EXPRESSION 'Ontario'
> 	      TEMPLATE 'null'
> 	      STYLE
> 	        COLOR 204 204 204
> 	        OUTLINECOLOR 5 5 5
> 	      END  #STYLE
> 	    END #CLASS
> 	    CLASS
> 	      NAME 'Québec'
> 	      EXPRESSION 'Québec'
> 	      TEMPLATE 'null'
> 	      STYLE
> 	        COLOR 204 204 204
> 	        OUTLINECOLOR 5 5 5
> 	      END  #STYLE
> 	    END #CLASS
> 	    CLASS
> 	      NAME 'Atlantic'
> 	      EXPRESSION 'Atlantic'
> 	      TEMPLATE 'null'
> 	      STYLE
> 	        COLOR 246 197 103
> 	        OUTLINECOLOR 5 5 5
> 	      END  #STYLE
> 	    END #CLASS
> 	    PROJECTION
> 	      "init=epsg:4326"
> 	    END
> 	  END  #LAYER
> What am I missing?
> Thanks again,
> Josh
> -----Original Message-----
> From: Howard Butler [mailto:hobu.inc at gmail.com]
> Sent: Tuesday, September 11, 2007 11:43 AM
> To: Josh Hevenor
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: Mapserver SDE 9.2 Question
> No, the 9.1 ArcSDE SDK dlls are not sufficient to connect to 9.2 with
> the 9.2 plugin.    The plugins are linked against each specific
> version of the ArcSDE SDK and have to be matched.  The use of plugins
> makes this less obnoxious than it was in the past, which required
> swapping out the entire libmap.dll, but it is still some hassle.
> The rules for ArcSDE MapServer connections are as follows:
> - If you have to connect to both ArcSDE X.1 and X.2 servers, use the
> X.2 version of the ArcSDE SDK.  You can usually connect to a X.1
> version server with X.2 version client DLLs without ill effect.
> - To connect to X.2 servers, you *have* to use X.2 versions of the
> ArcSDE SDK.
> - Do not use both the X.1 and X.2 versions of the plugins in the same
> MapServer map if you have to connect to both X.1 and X.2 version
> servers.  Just use X.2.
> Howard
> On Sep 11, 2007, at 10:21 AM, Josh Hevenor wrote:
>> I had a quick question on using the msplugin_sde_92.dll to connect
>> to an SDE service from mapserver. The SDE Notes from the README
>> file state the following:
>>             As of Map Server 5.0 (including betas and release
>> candidates), the following applies:
>> Steps to Enable SDE 9.1 and 9.2 Support in MS4W's Map Server
>> 1.    Make sure the ArcSDE? SDK dlls for 9.1 are available on... But
>> it doesn't mention arcSDE 9.2 SDK dll's for connecting to a 9.2
>> service. Are the 9.1 dll's sufficient? I'm just working through my
>> setup and thought I should clear this up as I go along.  Thanks,
>> Josh Hevenor
>> Application Developer
>> ____________________________________________
>> 5230 South Service Road
>> Burlington, Ontario
>> L7L 5K2  Canada
>> Phone: 905-333-4544 ext. 19
>> Fax: 905-333-0455
>> Cell: 905-320-7525
>> Email: josh.hevenor at dpra.com
>> Internet: http://www.dpra.com
>> <image001.jpg>
>> Attention:
>> Privileged/Confidential Information may be contained in this
>> message. Disclosure to any person other than the named recipient is
>> unauthorized. If you are not the intended recipient, please delete
>> all copies of this information and kindly notify the sender by
>> reply email. Opinions, conclusions and other information in this
>> message that do not relate to the official business of DPRA shall
>> be understood as neither given nor endorsed by it. DPRA and any of
>> its subsidiaries reserve the right to monitor all e-mail
>> communications through its networks. Thank you.
