how do I scale a shapefile?
Donal donal_regan10 at YAHOO.CO.UK
Wed Sep 12 05:35:39 EDT 2007
Just for the record, I think I have it with the following :
 ogr2ogr -s_srs ' +proj=tmerc +lat_0=33 +lon_0=129.5 +k=0.999900 +x_0=0
+y_0=0 +ellps=bessel +to_meter=0.001' -t_srs EPSG:30161 out.shp in.shp
and I got my settings by looking up the value for 30161 in the
/usr/local/share/proj/epsg file.
Donal wrote:
> Hello.
> Is it possible to somehow scale a shapefile?
> For example when I use ogrinfo to examine a shape file I see that it has
> an extent of
> Extent: (33791266.000000, 8769802.000000) - (34589323.000000,
> 9369802.000000)
> with a
> Layer SRS WKT: (unknown)
> I have been told that they should be epsg:30161 but are out by a factor of
> 1000.
> Is there some tool I can use that will scale the shapefile contents?
> Or is there a way to tell mapserver to divide the extents and coordinates
> by 1000?
> I hope this makes sense and is possible to achieve.
> Thanks,
> D.
View this message in context: http://www.nabble.com/how-do-I-scale-a-shapefile--tf4427886.html#a12632057
Sent from the Mapserver - User mailing list archive at Nabble.com.
